Mysterious misfire ONLY when low HV battery, but No DTC’s
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Baz2473, Jan 23, 2019.
  1. Baz2473
    Baz2473 Junior Member
    37
    16
    Kent. England.
    Hey all. Has anyone else encountered the random, mysterious misfire that only sometimes happens and only ever when the HV battery is low and never throws a single fault code?
    Here’s a little background info on the car.
    2015 last of the gen 3’s
    196,000 miles.
    No loss of oil or water.
    Never ran low on oil.
    Regular services.
    At 195,000 it developed the famous engine knock on startup along with this new mysterious misfire (or at least it feels like a misfire)!
    Stripped out the entire egr system. (Cooler, valve, Pipe & intake manifold) cleaned throughly, replaced the PCV valve, introduced an oil catch can, removed and ultrasonic cleaned the fuel injectors. Replaced all 4 spark plugs. All had no effect on the misfire but did cure the startup knock...
    Anyone have any ideas or experience with this? Any help would be appreciated.
  2. JC91006
    16,477
    8,394
    Many have reported the low SOC misfire. Has the car overheated before? Failed water pump/inverter pump?
  3. Baz2473
    37
    16
    Kent. England.
    Never overheated and no apparent problems with either pump.
    49,387
    plugs, injectors, throttle, maf?
  5. Baz2473
    37
    16
    Kent. England.
    New plugs. Ultrasonic cleaned injectors, maf untouched.?
  6. JC91006
    16,477
    8,394
    So basically you can drive the car trouble free as long as the battery SOC does not go to 2 bars? When I read about this problem 2 years ago, I couldn't figure out how the low SOC would do that to the engine. 2 years later.....I'm still unsure...............
    I did buy a car with the low SOC misfire problem, but that car also had a bad head gasket, that was repaired using some coolant additive. Long story, that car was sold before I even registered it to my name.
  7. Baz2473
    37
    16
    Kent. England.
    That’s correct. It runs like a dream unless that battery is under the half way mark. The lower it is the worse the misfire?
  8. JC91006
    16,477
    8,394
    So the remedy is to not let the car SOC get low. I would recondition the battery now and get it as strong as possible. Then whenever you're at a stoplight and you see the SOC drop low, do a force charge on the car and get the SOC back up (only take 30 seconds or less)
  9. JC91006
    16,477
    8,394
    I know you cleaned out the EGR valve, I wonder would replacing it help? It's not hard to get to (much easier than the damn cooler)
  10. Baz2473
    37
    16
    Kent. England.
    That is what I currently do, I was just hoping that there was a permanent fix rather than messing around like that can’t afford a new hybrid battery...
  11. Baz2473
    37
    16
    Kent. England.
    Was thinking this myself but wasn’t sure if that could be the reason for the misfire? Do you know if unplugging it would be a way of testing if this would cure it. (If I unplugged it when the valve was closed) ?
  12. JC91006
    16,477
    8,394
    I'm going to have to defer to some of the guys that knows this stuff better, I don't really know the answer......in 24 hours, you'll get get some more responses.
  13. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Mine did the same and finally blew a hole in the engine 2 months later
  14. Mendel Leisk
    38,651
    Where was the hole; did you figure out what failed?
  15. tankyuong
    1,555
    660
    Central MO
    The hole was in the block, replaced the engine
  16. bisco
    49,387
  17. Baz2473
    37
    16
    Kent. England.
    Thank you for your help.
  18. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    What are you using to read codes?
    Have you tried moving the coils around and see what happens?
    Still got the old plugs for comparison?
    No lights on the dash?
  19. Baz2473
    37
    16
    Kent. England.
    Techstream to read codes. (There is none)
    Swapping coils around made no difference.
    Yes still have old plugs. (See attached pic)
    No warning lights what so ever.
  20. Baz2473
    37
    16
    Kent. England.
    Ok. So I’ve decided to take off the entire EGR system again including cooler and IM and give it a through ultrasonic clean. Hopefully this will help. ?
