Mysterious shutdown this weekend
Discussion in 'Gen 2 Prius Main Forum' started by subinthapa, Apr 7, 2011.
  1. subinthapa
    subinthapa New Member
    I haven't visited this forum in quite a while, mainly because my 06 Prius has been as trouble-free as I had hoped it would be - but then something weird happened this weekend. Fifteen miles into an outing, at a steady 65 mph on perfectly smooth freeway, the VSC light came on with a beep, followed by the ABS light a couple seconds later. The funny exclaiming circle in parentheses followed a few seconds later, and while I was maneuvering to get off the freeway at the next exit, the big red Triangle of Death came on, along with a steady tone and the cryptic statement "Problem" at the top of the MID. Then I noticed that power steering and brakes were gone, and the hybrid system was no longer providing power. We made it off the freeway safely, and I tried shutting down, waiting 30 seconds and powering back on, with no change to the warning lights. Five minutes later, after calling for a tow, I cycled to the On-Not Ready state to roll down the windows, and noticed the TOD was not on, but all the other lights were. The "Problem" statement was still locked on the MID as well, which was blocking me from using the GPS to get the phone number of the nearest Toyota dealer. Cycling back to Accessory state helped me get to the phone number.
    When we got the car to the dealer, all the lights except the TOD were still on, and the dealer got the following current DTCs: C0215, C1300, U0121, and B1421. There were four historical codes, but the tech did not think those were related. They began by troubleshooting the left rear speed sensor, which tested fine, so they cleared the codes and nothing came back. I had them test-drive it before I picked it back up, and nothing else has come up since - it's like nothing ever happened!
    The thing I have a hard time believing is that, according to the dealer, the car has no record of the hybrid system shutdown. Can this be true? I have a hard time believing the Toyota engineers wouldn't have made sure there was some record of a hybrid system shutdown. Even Windows manages to log BSOD occurrences! It is also weird that the dealer doesn't understand how the codes could have gone away without any maintenance on their part - our service rep gave me the impression that they didn't even jiggle the wires or reseat connectors. Any thoughts or similar experiences? At this point I plan on treating this like an isolated Windows shutdown, mainly because I can't think of anything else to do.
  2. Patrick Wong
    18,200
    6,493
    Four items for your consideration:
    1. Was the inverter coolant pump replaced under the limited service campaign yet? If not that should be done now.
    2. Check the inverter coolant reservoir, looking for fluid turbulence within, when the Prius is READY. If you don't see this then the pump is not running and you should immediately have that replaced.
    3. Have you driven more than 15 miles at a time, since your weekend failure? If yes, what was the duration and average speed of your longest drive?
    4. Regarding the lack of drivetrain codes, I am wondering whether your 12V battery is marginal which caused the engine and hybrid vehicle ECUs to lose their memory of stored DTC. Has the battery been replaced yet?
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I was thinking the same thing Patrick. Especially if the inverter got hot enough to disable the DC-DC converter, which it probably would have.
  4. richard schumacher
    7,664
    1,043
    United States
    That all sounds very much like the inverter coolant pump failure on mine, as Patrick suggested. That should be investigated and if necessary repaired immediately, to prevent possible damage to the very-expensive inverter.
    But do also check the 12V battery as one simple possibility that should be eliminated:
    http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html
    (If you have any questions or comments specifically about that thread or the procedure please reply in that thread.)
  5. subinthapa
    Thanks all. The inverter coolant pump was replaced on the recall well before this happened, and they also replaced the ICE coolant pump under warranty at the same time, although I had had no signs of problems with either. I also just did the battery diagnostic check described in previous posts here, and that seems fine. The dealer put 37 miles on the car when I authorized them to test drive it, and they must have driven it pretty hard, because they put a big dent in the mileage. Since I picked it up, we've driven the same distance under about the same conditions (although it has been considerably cooler since that day), but no longer or harder drives.
    I happened to talk to another friend who went through the HV coolant pump failure, and it was kind of surprising to hear that the car gave no specific information on why it was shutting down. They tried to limp home by stopping for a while and starting back up, since they didn't know what was going on and stopping was enough to make the TOD go away. The difference in my situation seems to be the ABS/VSC trouble codes. It's hard to imagine why those would come on, cause a HV shutdown, stay on until cleared, and then not come back.
  6. dogfriend
    7,512
    1,189
    Carmichael, CA
    Is the 12V battery the original one? If you have a Scangauge, you can watch voltage during shutdown to see how far the coolant heat transfer pump pulls it down.
  7. Patrick Wong
    18,200
    6,493
    Pls check the inverter reservoir when the car is READY to see if fluid turbulence exists, as I suggested above. That is a really easy thing to check.
    Further, the battery voltage check is not reliable unless you do the check first thing in the morning after the car has sat undisturbed overnight, prior to making the car READY.
    I offer a scenario below which would explain all of the symptoms that you provided above:
    Assume that:
    - The inverter coolant pump failed, or was incorrectly installed so that air remains in the system; and
    - The 12V battery is in marginal condition and will not offer a safety reserve.
    Please note that the inverter will not overheat until you drive a substantial distance, which depends upon ambient temperatures.
    Now, you go for your 15 mile drive. The weather is sufficiently warm so that the inverter finally overheats as we assumed the pump is not doing its job. At that point, the DC/DC converter within the inverter shuts down and voltage on the 12V bus starts dropping below the nominal 13.8VDC.
    Now the 12V battery must bear the load. However since we assume your battery is in marginal condition, it cannot do so. This causes the 12V bus voltage to sag to the point where the various ECUs shut down. Hence the power steering and brakes do not operate. In addition, the engine and hybrid vehicle ECUs will lose whatever DTC had been logged.
    The skid control ECU is highly sensitive to 12V power since it depends upon that for proper functioning. It will turn on the VSC, ABS and ((!)) brake warning lights. That ECU, unlike the others, will retain DTC even when 12V power is lost.
    It has been proven through many prior posts that the Toyota dealer equipment is incapable of correctly testing the Prius 12V battery. You'd think that would be a really simple thing to do; however many false reports of "battery OK" have been received.
    You can easily prove or disprove my hypothesis by checking the inverter pump operation.
    5 people like this.
  8. subinthapa
    Thanks Patrick, that's a very thorough and clearly explained scenario. I'll observe the reservoir tomorrow, and use my handy-dandy analog multimeter to monitor voltage fluctuations on the 12V battery during the cold start-up sequence. Your idea seems more likely since it is the original battery.
  9. subinthapa
    So I did my tests today. First thing on a very cold LA morning, I connected my analog voltmeter to the jumpstarting terminals under the hood and removed the inverter coolant reservoir cap. A few white flecks on the surface of the fluid looked to be crystallized coolant knocked loose from removing the cap. Voltmeter read over 12.5 volts. Had the wife step on the brake, and the needle deflected a bit, but stayed above 12.5. Had her turn on the lights and it dropped to somewhere above 10 volts, below 12.5, and steady. Put the car in Ready and it jumped to around 14V. Inverter coolant immediately started circulating smooth and steady, and it looked clean and clear. I only watched it for 15 seconds or so, but I was just looking for obvious problems.
    @Patrick: I have a question about your possible scenario. If it actually were to occur with the exact sequence of symptoms I observed, then the inverter would have failed without immediately triggering a warning to the driver. I can see the bad 12V battery causing the codes to not be saved. Could the inverter fail without independently triggering an alarm, so the first symptom a driver would observe is the failure of dependent systems?
  10. Patrick Wong
    18,200
    6,493
    Thanks for posting the results of your tests. We now know the inverter coolant pump is not an issue.
    Yes, if the DC/DC converter within the inverter were to shut down, you would not see a warning specific to that. The warning would appear when the systems which rely upon 12V power notice the reduced voltage and start to complain.
    Unfortunately your voltage reading (above 10V, below 12.5V) is not sufficiently precise to say much about the battery's condition. If it was 10.1V then it definitely needs to be replaced now. If it was 12.4V then it would be OK.
    If your measurement cannot be more precise, then since a question remains about the 12V battery's condition I would recommend replacing it now.
    Perhaps you might take a nice long drive (30 miles or more) today and see what happens? Good luck.
  11. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi S,
    A drop to 10 volts with the lights on, from 12.5 volts sounds like allot to me. Which indicates allot of resistance between the battery and the jump-start terminals (and probably the lights). Have the battery attachments (battery is in the right rear of the car) checked to be tight, and not corroded first. Clean them if they look the least bit dirty.
    To see if this problem is fixed, and not the battery, compare the battery voltage at the battery posts, to the voltage at the jump-start terminals, and they should not be more than .5 volts (?) different, when the car light load is present.
  12. subinthapa
    Well, the mysterious shutdown remains mysterious, but more importantly, isolated. We took a 100-mile road trip this week, and on the way back went through a small mountain town where we encountered thirty miles of steep, winding climbs and descents in 80-degree weather, and there was no sign of trouble at all. I'm still holding the 12V battery suspect, but it can't be the primary cause, and since we have had no other symptoms from it, I plan on leaving it alone for now. I'll update this thread if anything else comes up. Thanks for everyone's help.
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Have you checked the 12V battery connections? That could easily cause intermittent problems.
    Tom
  14. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Not wanting to hijack this thread but to check operation of the inverter pump you remove the top off the inverter coolant and then put the car in ready and look for movement in the fluid?
    Does the car have to be warm or cold first thing in the morning? Just gonna give mine a check after the odd inverter error codes I go (see other thread).
  15. Patrick Wong
    18,200
    6,493
    Actually it is not necessary to remove the coolant reservoir cap, to see the turbulence in the fluid.
    The inverter coolant pump should be running at all times that the Prius is IG-ON or READY so it doesn't matter whether the powertrain temperature is cold or hot.
  16. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    It isn't only weird that you would describe the battery voltage under load as "somewhere above 10 V" but also tha the original 2006 12 V battery would read 12.5 V on a cold morning.
    My '07 battery was at 12.0 before it was replaced and it was never misused, unless of course the car was sitting in the dealer lot before I purchased it.
  17. dbandrew
    dbandrew New Member
    Atlanta, GA
    The same (or very similar) thing has happened to me three times now. Here is a quote from my original post. You can search my post to see the entire thread. Car is in the shop as we speak. So far no help.
    2006, 2G, 43000K. This has happened twice now. Both times on an extended trip of 3+ hours in hot weather: Cruising along at about 70 MPH, the engine just quits. RED Triangle; check engine light; and vcs light. Turned everything off. Car would not restart right away, but after waiting 15 minutes or so, the car restarts and runs fine. All warning lights off except check engine light.
  18. subinthapa
    It's back!
    My wife had the same symptom again this morning. She was on her way back from a three-mile trip when the same cascade of warnings came on and hybrid power turned off. She had three small kids in the car and two miles of quiet, residential driving left, so I talked her through driving home without the hybrid system (I'm a bit surprised this worked). The car is going back to the dealer with explicit instructions to exhaustively test the 12V battery and connections. I'm still wondering if something in the brake system could be the underlying cause, though, because no other 12V-related symptoms have come up, and we're 5K miles past the previous shutdown.
  19. Patrick Wong
    18,200
    6,493
    You are wasting time by "exhaustively testing" the 12V battery. Replace it now.
    Your car may well have another issue (for example, the inverter may be flaky), but the 12V battery is not very expensive. Instead of spending labor $ to test it, just replace it.
  20. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    12v battery?... if it's original.... probably.. in part
    might want to give your ignition coils and spark plugs a check. this sounds like it could be related to those. the trick thing is.. they don't throw their own codes.. it's as if the system doesn't know they are there... till you unplug one.. then it throws a code...
