mystery box tied into harness behind drivers rear kick panel... anyone?
Discussion in 'Gen 3 Prius Main Forum' started by sukatoro, Aug 5, 2018.
  1. sukatoro
    sukatoro Junior Member
    37
    Houston Tx
    hi everyone, was installing a backup camera today and when removing drivers rear kick panel I found... well I don't know what it is, but looks spliced into the factory harness, and is wired in with a type and gauge of wire seen nowhere else in the car. part of an aftermarket security system, or... do not know. can anyone identify?
    its the black box with grounding hole, no identifying marks on it, no manufacturer name at least.
    mystery box — imgbb.com
  2. sukatoro
    37
    Houston Tx
    huh, nobody recognizes then? it looks kind of out of place
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    288
    66
    Phoenix
    Is there a blue button with a blue LED that is attached somewhere in that area with one screw? If so, it's a KARR aftermarket system.
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    Could it be a LoJack transmitter? Call LoJack and give them your VIN and they may be able to confirm.
  5. sukatoro
    37
    Houston Tx
    no button as far as I was able to spot, so it definitely isnt a factory part of the car then I take it? according to techstream I don't have a security system aside from the factory immobiliser..
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    Chill. Millions of people don't see posts here instantly like they might on Twitter.
    Jumping to that conclusion after only 10 hours or so is probably not justified.
    ESPECIALLY when most normal people are ASLEEP during those 10 hours !! :D
    There aren't any markings on it that look like Russian, is there ????
  7. Grit
    Grit Senior Member
    6,111
    4,039
    Wilkes Land
    Some people hibernate during the day and not seen this post yet.
  8. phoenixgreg
    1,157
    288
    66
    Phoenix
    It kind of looks like a relay or flasher? I see it has a tiny red reset button on it too. I'd say don't mess with it or it might take down part of the headlight system. Are you the original owner? Has anyone upgraded the headlights or added fog lights?
  9. sukatoro
    37
    Houston Tx
    sorry for any perceived impatience friends, really wanting to button up the car and not really inclined to leave it in place, getting a better look now, here's a better pic of how it looks the way I found it..:
    IMG 20180806 150708 — imgbb.com
  10. bisco
    48,945
    it's probably security, just ignore it.
    dubit likes this.
  11. sam spade 2
    7,035
    2,782
    2017 Prius c
    OK, much better picture.
    That looks very much like an inline fuse holder......or maybe a power lead filter/choke.
    nekoashide likes this.
  12. BZzap!
    1,607
    877
    I agree with Sam Spade 2. It appears to be some sort of filter. The wire looks like a coaxial cable or antenna lead for a transceiver.
  13. Mendel Leisk
    38,207
    The perceived impatience is mostly in the eyes of one responder. :rolleyes:
  14. nekoashide
    nekoashide Junior Member
    25
    US
    It's an inline fuse mounted and instead of leaving it hanging they got a mounted one, typically for aftermarket and tied directly into the battery at some point. Have any aftermarket work done? Or maybe if you bought it used they took out the aftermarket stuff and left you with that guy.
    edit: look for signs of a tow hitch
  15. padroo
    padroo Senior Member
    2,763
    2,250
    How many wires go to it?
  16. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Looks like an inline ATO fuse holder to me with a pop off top to access said fuse. I assume you're not the original owner and thus guessing about aftermarket items?
  17. ChapmanF
    15,068
    What's the location? I can't really tell from any of the pictures (except it seems to be near a retracted seat belt buckle), and I'm not sure what "driver's rear kick panel" means to you. Is that the left rear seat belt showing, so this thing is maybe on the rear wheelhouse, past the aft edge of the rear door? Is that the rear door switch showing in the photo?
    You might put me down for the noise filter for the rear window defogger. In my Gen 1 it was up in the C pillar closer to the window, but Gen 1 was a sedan. In the liftback it might be in the actual hatch, but I don't know.
    We're all going to keep guessing until somebody whose techinfo subscription is paid up goes and finds it in the wiring diagram (or doesn't, and that would make a stronger case that it's something aftermarket).
    -Chap
  18. DavidA
    2,325
    1,811
    Chicago western burbs
    +1. Was the car bought used? Was it ever a leased vehicle?
  19. sam spade 2
    7,035
    2,782
    2017 Prius c
    And nasty comments like that are useful to anybody.......how exactly ???
    What I said is absolutely TRUE.
  20. Johnny Cakes
    Johnny Cakes Senior Member
    998
    756
    Virginia, USA
    I think that is the very point Mendel Leisk was trying to make.
    Just because something is true doesn't mean it needs to be said. Also, how something is said is often more important than what is said.
