Mystery noise behind passenger side dash - help me identify it?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by metamatic, Oct 29, 2014.
  1. metamatic
    metamatic Member
    114
    16
    Austin, TX
    2020 Prius
    I've put a recording on Soundcloud:
    The noise is best heard at 1:00 onwards, after everything else has stopped. I left everything else in the recording so you'd have an idea as to the volume level relative to the engine etc.
    Any ideas? It sounds like some sort of solenoid repeatedly trying to do something, or a broken fan or pump.
    We already had the dealership attempt to fix the problem once, so I'm hoping someone will have encountered the same noise and recognize it.
    Thanks!
    52,390
    what are you driving? if it's a prius, probably a bad mfd.
    52,390
    btw, it's so cool that you've made a hunnert posts in ten years.(y)
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    If you're stationary @ 1:00 then it's not what I first thought it sounded like = bad tyre (tire in US) - I've heard a similar noise from the rear passenger-side wheel when one of the belts in the ty(i)re had separated on a friend's Audi when he loaned it to me many years ago! Either that or wheel-bearing!
  5. metamatic
    metamatic Member
    114
    16
    Austin, TX
    2020 Prius
    This is a 10 year old Prius. The noise is audible when the car is completely stationary but in "engine on" mode. The noise starts and stops seemingly at random.
    And yeah, I joined when I was looking for a Prius 10 years ago, but the intervening period has been pretty uneventful. The car has just run and run. Probably time to buy another one next year, but as I say I already paid to get this noise fixed, so I'd like to solve the mystery.
  6. metamatic
    metamatic Member
    114
    16
    Austin, TX
    2020 Prius
    OK, some more info.
    The noise seems to be heat related — when the car's cold in chilly weather, no noise. As the car heats up, it gets noisier. When the engine's been running a while and you stop, the rattle is audible until the car cools down.
    Also, we tried stopping and opening the hood to locate it more precisely, and it seems that although inside it's most audible on the passenger side, when you lift the hood the noise is from somewhere to the right of the Hybrid Synergy Drive box. Unfortunately, I've no idea what's down there?
  7. bisco
    52,390
    kinda sounds like my wifes sewing machine.
  8. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
