Mystery on my dash
Discussion in 'Gen 2 Prius Main Forum' started by wegie12, Oct 17, 2007.
  1. wegie12
    wegie12 New Member
    Hello everyone,
    I bought a Silver 2007 Prius hatchback with package #6 two weeks ago. I love it so far. its everything I hoped it would be. I have a question. there is a small dark brown square thing sitting on my dash on the passengers side up next to the windshield. looks like a piece of chocolate candy. looks like it is sitting on a 3"X3" plastic base of the same color. there is a wire leading from the back side toward the windshield and down into the dashboard of the car. I have looked in every book and folder that came with the car and cant find any information on its identification. my husband thought it might be for the auto on/off headlights but the book describes that sensor as being in the drivers side and I can see the "bubble" that is, I believe, the headlights sensor. So we cannot figure out what the one on the passengers side could be. does anyone have the answer?
    Thank You
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Sounds like a satellite radio antenna
  3. meshell
    meshell New Member
    65
    do you have satellite radio...it sounds like you are describing the antenna...just a a thought...
  4. lmalchiodi
    lmalchiodi New Member
    17
    You've precisely described my XM satellite radio antenna. :)
    I'm sure that's what it is.
  5. richlaz
    richlaz New Member
    Long Island, NY
    <div class='quotetop'>QUOTE(Echo111 @ Oct 17 2007, 12:33 PM) [snapback]526914[/snapback]</div>
    I have a 07 with #6 package, but don't have auto on/off lights. Is that only offered in certain regions?
  6. Tideland Prius
    16,445
    <div class='quotetop'>QUOTE(richlaz @ Oct 17 2007, 10:22 AM) [snapback]526947[/snapback]</div>
    By regions you mean country, then yes. It's only available in Canada.
  7. Bohous
    Bohous New Member
    316
    Boston-ish
    It's definitely a bomb.
    Slowly...step...away.....from...the....car.....
    Oh, and call Keanu Reeves ASAP.
  8. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    Every Prius in America has Auto "off" lights. Just turn the car off and open the driver's door. The auto "on" lights are an option for other countries, like Canada where all the time lights are required.
  9. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    <div class='quotetop'>QUOTE(subarutoo @ Oct 17 2007, 01:15 PM) [snapback]527014[/snapback]</div>
    I'm not sure you understand, so please don't take offense.
    The auto on headlamps the Canadian cars come with is separate from the daytime running lights (DRLs). It's a function on the light switch on the left stick that has "off, park lights, on, and auto" positions. In the "auto" position the headlamps will come on as it gets dark out (sensor on dash at base of windshield). Curiously, the dash lights don't dim when the headlamps first come on, they dim when it gets a little darker out. If left in the "auto" position, the headlamps will go out when you turn off the car and open the drivers door, as do the DRLs, and the headlamps in the US car if the switch is left on.
    Note that the DRLs use the headlamps run in a dim configuration, and when the headlamp function comes on the lights go to full bright. Further, this does not apply to the HID headlamps, as we don't have them up here. I would guess if they became a Canadian option, the turn signals would be used, probably having the bulbs replaced with a dual filament one, the brighter one used for DRLs like the Chrysler mini-vans and other vehicles.
    Also, the DRLs don't come on when you turn on the car if the parking brake is engaged. They turn on when it is released. If the parking brake is not engaged when you turn on the car, they come on. They don't go out when you then engage the parking brake. Curious eh? :p
  10. wegie12
    wegie12 New Member
    <div class='quotetop'>QUOTE(LynneM @ Oct 17 2007, 11:59 AM) [snapback]526932[/snapback]</div>
    Yes, it is the xm radio antenna. Thank you all for the quick replys. I am surprised the salesman did not seem to know.
  11. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(Echo111 @ Oct 18 2007, 12:05 PM) [snapback]527410[/snapback]</div>
    You haven't dealt with enough car salesmen. There is no end to what they don't know. What's worse, they'll never say "I don't know." They'll make up something.
  12. Inches
    Inches Member
    117
    San Mateo, CA
    <div class='quotetop'>QUOTE(Bohous @ Oct 17 2007, 10:45 AM) [snapback]526961[/snapback]</div>
    Waiting for OnStar to activate :lol:
