NAPA POAT Asian Red coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mgoddard92, Dec 15, 2022.
  1. Mgoddard92
    Mgoddard92 Junior Member
    22
    Hey guys, I just did head gasket on my 13 Prius three and having issues getting the HOAT coolant, I have some NAPA Asian vehicle POAT coolant, can I run this in just the engine? System is completely empty so mixing coolant isn’t a issue
    I know I should use toyota coolant but I’m a ways from the dealer.
  2. Tombukt2
    Tombukt2 Senior Member
    13,384
    2,408
    Durham NC
    You can I use the Asian red stuff from advance Auto and other places in the inverter and in the radiator I've had over 80,000 miles with no trouble so far at least not from the coolant or anything related to it that I know of I'm driving a 13 persona Good luck
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Are you sure it's completely empty? There's usually a good bit of coolant in the heater core and hoses that doesn't get drained.
    That's why the replacement interval is shorter after the initial coolant drain and fill, because there's a mixture of old and new coolant.
  4. xliderider
    8,140
    3,277
    Honolulu, HI
    FWIW, I used the Asian red coolant from NAPA in both coolant loops in our 2011.
