narrowing down a strange sound
Discussion in 'Gen 2 Prius Main Forum' started by trip, Sep 22, 2011.
  1. trip
    trip Junior Member
    25
    Illinois
    Hello,
    This is my first post and and I appreciate this forum already. I realize this is a very subjective subject, but I'll do my best to describe the issue. First off it's a 2008 Prius with 80K on it.
    There is a "new" sound that has started coming from the front of the car in the engine compartment or even lower. It is a turning turbine like sound that is mostly obvious when driving at 60 mph, but my guess is that it is always there, but not as audible at lower speeds. The air and heater are both off and have no effect on this sound. The only thing that could have had anything to do with it is that a day or two before, the tires were low so I filled them to 40 psi. The other thing is that it clicked over to 80K the last week and the friendly red maintenance required light came on.
    Any thoughts as to what this might be? Is there any variable that I'm not describing here that I should be?
    Thanks for the help.
    Tom
  2. max-greece
    max-greece New Member
    Greece
    Well I would expect the first thing to do is to get that red light investigated and to tell the mechanic about the strange noise. One of the problems with strange noises on a Prius is that they are built in - it even mentions them in the manual. I think the ones that they are referring to are for the re-charging system - but that isn't on all the time.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    +1 on the red light. I think maintenance light is yellow, not red. Red warning lights are reserved for serious problems.
  4. ursle
    ursle Gas miser
    1,049
    192
    NH
    Just have to mention that the front wheel bearings make that sort of sound, as it's speed related they come first to mind.
    A free OBD2 read at pep boys or an auto parts dealer will tell you about the red light code, Toyota dealer won't be free.
    And welcome to prius chat:)
  5. trip
    trip Junior Member
    25
    Illinois
    Thanks for the responses so far folks. This morning I was listening again and can relate the sound to the should inside a plane when you're climbing.
    And yes the light is yellow. Caution color as opposed to panic ;)
    Is it common for the front wheel bearings to go with 80K? I suppose anything is possible.
    Also, tipping my hand here, can someone clarify what OBD2 means?
    Tom
  6. ursle
    ursle Gas miser
    1,049
    192
    NH
    My 06' bearings went between 45 and 60k, obd2 is the on board diagnostics system, you can pick up a consumer obd2 reader or as many on pc do a scanguage2 which allows you to customize up to 4 different values and reads and resets trouble codes.
    Might be worthwhile to have a competent mechanic do a test drive and or check for bearing noise.
  7. 2009Prius
    2,705
    512
    63
    If it's just the yellow maintenance light then I won't waste time or money trying to read trouble codes - there is none. The light can be turned off following instructions in the owner's manual. Do keep us updated on the noise issue. One of the member here had wheel bearing going bad while still under warranty.
  8. trip
    trip Junior Member
    25
    Illinois
    Thanks for the info folks. One last question if I might. What am I looking at to fix that-a general price for an honest mechanic? And what are the risks of continuing to drive until I'm forced to repair? OK that's two questions.
    I bought it used, so I'm not sure if there is anything under the warranty other than the batteries, which I believe are covered up to 100K
    I'll keep posted and keep looking around the site too! My appreciation.
    Tom
  9. bisco
    52,386
    how many miles on the tires? how does the tread look? you could be right about pumping up the pressure. let it back out and see if the noise goes away. if it's a bearing and it seizes up, you're stuck. you probably have quite a while though. jack it up and spin the front tires to see if there is any friction sound or feeling. all the best and welcome to p/c!
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    My 2006 just started making this sound at 65,000 miles. Naturally, it started while I was outbound on a 1,500 mile trip, so I had to worry about it the whole way. On the other hand, it gave me a lot of time to experiment. Here is what I found:
    1) The sound is a turbine-like whining coming low from the front, most likely on the driver's side (left side). It is mechanical, as it sometimes includes a rumble that can be felt. It is definitely not inverter whine.
    2) The sound varies directly with wheel speed. Speeds around 60 mph appear to generate a resonance that intensifies the sound. I don't hear it at all below 20 mph, but it may simply be too faint to hear.
    3) The sound is the same with our without power: shifting to N causes no change.
    4) Engine RPM freely changes without affecting the sound.
    5) Hard turns to the left at speed reduce or eliminate the sound. These are turns fast enough to generate noticeable lateral force.
    6) There are no warning lights or other indications of trouble. Mileage remains normal.
    Conclusions:
    From these symptoms I surmise that the bearings are going on the front driver's side. Presumably the left turns change the bearing loading and suppress the sound.
    I will make an appointment at the dealer this week. Expect a follow-up post.
    One more interesting observation: After driving 1,200 miles with a funny noise, it's amazing to see how many strange symptoms I noticed (imagined) just because I was looking for trouble. Even with my fairly extensive knowledge of the Prius, I borrowed trouble at every available opportunity. The placebo effect lives, even among technical experts.
    Tom
  11. hill
    8,916
    I'd agree with the bearing guess. It kind of makes one long for the day when bearings had zerks - in stead of being sealed. It's one of those imponderables - how some of us have hundreds of thousand of miles on the Prius with no bearing issues ... while others ....
    Nope . . . you'd think so, but it aint so. For example, our Lexus hybrid lets you know it's time to change the cabin filter with a red triangle. What ever gets programmed into the maintenance schedule get the same thing.
  12. qbee42
    18,058
    3,079
    Northern Michigan
    Fixed. Just as suspected, the strange sound was coming from the driver's side wheel bearing. As described by the Toyota tech: "Your left front hub assembly has failed." The whole unit is replaced as an assembly. It took about two hours and cost $526; $106 for the part, $380 for labor, and the rest miscellaneous charges and tax.
    The tech said that they have replace "quite a few" of these. Mine went out at 67,000 miles.
    Edit: I mistyped the mileage, which I have corrected to 67,000 miles, not 37,000. Incidentally, this is the first repair on my Prius.
    Tom
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Tom describes my event also and my front driver's bearing went out also at
    30,000 miles. It was replaced under warranty.
    The tip off is a change in sound when turned. Just drive down an empty road and whip the car around a little like your driving around a sudden obstacle.
    But not that fast. Just enough to put a turning load on the car.
  14. trip
    trip Junior Member
    25
    Illinois
    "It took about two hours and cost $526; $106 for the part, $380 for labor, and the rest miscellaneous charges and tax."
    That sounds like what's happening in my case Tom. Mine is getting worse so I'm sure it's not the tire pressure as I was hoping. So I have to ask why would they just do one side? Wouldn't it be best to do both sides? If I extrapolate the above cost should I expect to pay 1K for both front wheels?
    Thanks again,
    Tom
  15. qbee42
    18,058
    3,079
    Northern Michigan
    The failure of one side is not an indication that the other is about to fail. In other words, the service life of these hub assemblies seems to be highly variable. Some people get 150,000 miles out of them, some have them die young.
    Additionally, there really isn't a time or cost savings in replacing both sides at the same time, other than the convenience of one trip to the dealer.
    Tom
