NASA Artemis 1 Moon Rocket Launch! - SCRUBBED
Discussion in 'Fred's House of Pancakes' started by ETC(SS), Aug 29, 2022.
  1. ETC(SS)
    6,545
    ...could have been worse, I guess.
    jerrymildred and Mendel Leisk like this.
  2. Mendel Leisk
    38,669
    Substance starts around 2:10.
    Louis19 and ETC(SS) like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Anyone surprised?
  4. ETC(SS)
    6,545
    Nope.
    jerrymildred likes this.
  5. ETC(SS)
    6,545
    They're trying to fix Artemis on the stand, but if the rumors are correct it's a fairly non-trivial problem.
    There were rumors about a crack in a tank, but it was merely the foam.
    Since this is a fire-and-forget missile and the heat shield is buried a little deeper than before, flying foam is a little less stressful to the passengers.
    HOWEVER (comma!)
    Engineers also identified a bleed in a liquid hydrogen line meant to cool the four RS-25 engines on the bottom of the rocket’s core stage.
    (Monday was the first full reloading of cryo fuel.) Hydrogen was also a problem in a countdown test in April, resulting in numerous repairs. Another test in June had more success, but still experienced some leakage.
    I'm not well educated but I'm seeing a pattern starting to develop.
    The RS-25 rocket engines aren't new.
    The RS-25 probably stands for something like Aerojet Rocketdyne Shuttle Engine- 25 something...meaning it's been kicking around in the NASA programme since the late 70s (First STS was April-1981) so one might think that they would be plug-and-play for yet another NASA hybrid launch vehicle - part solid rocket and part liquid.
    Buuuuut, no.
    Different mission profile.
    Different engine operating parameters.
    NASA might be learning a lesson that they shouldn't have to for two reasons. They might have been better off clean-sheeting the engines for the SLS rather than trying to adapt one from the 80's..."to save time and money."
    The first reason they ought to know better is that they've been doing this since the 60's....with hard lessons going back to the 50's.
    EVEN IF they're not the cheapest and fastest at DOING stuff, they should at least be able to identify pitfalls early.
    ADMINISTRATION after all, seems to feature prominently in their name.
    They should have seen this coming and learned from tragic lessons in the 60's, retaught tragically in the 80's that bad assumptions kill as many people and rockets as dates circled on calendars do.
    They also should have seen this from over the horizon because they're not the only players on the field anymore.
    They should have learned from Musk.
    IIRC, Musk said that he horribly underestimated the difficulty in developing the Falcon Heavy, because after all, it's just three Falcon Nine's strapped together with a payload atop the one in the middle - right?
    That's easy, isn't it?
    NASA is already late, and they're already over budget, and they're married to the RS-25s which will probably prove to be a great engine for this task, albeit more difficulty repurposed than the pencil pushers anticipated.
    So.....
    Since this will ultimately be crew-certified launch system, they ought to throw away the calendars, back-haul the rocket and get it right.
    ...the FIRST time.
    Remember:
    The Shuttle Programme got it right the first time....and the second...and the 20th.
    They went on to lose 14 of the 355 folks that flew in them... (according to the wikis, and yes....many of those folks were repeat customers!)
  6. bisco
    49,402
    at least they didn't send it up thoughtlessly
  7. ETC(SS)
    6,545
    meh....
    We'll see.
    It's easy to be a quarterback on Monday....BUT(!)
    Those are OUR bucks on the pad.
    We may not call the plays, but they work at our pleasure.
    They didn't have a choice but to scrub it.
  8. bisco
    49,402
    find me a pol who would scrub it, i don't think we have a choice. when you borrow and print money, can you really call it our bucks?
    we will pay the piper though
  9. Doug McC
    Doug McC Active Member
    999
    375
    Midwest
    2022 Prius
    I, for one, am glad they delayed the launch, following their procedures to ensure they do whatever they can to get it right. I also hope they aren’t being exposed to the opinions of folks on social media after working hard to get to this point.
    Louis19 likes this.
  10. ETC(SS)
    6,545
    It's easier when you have kids and grandkids.....
  11. tochatihu
    tochatihu Senior Member
    9,046
    3,528
    Kunming Yunnan China
    2001 Prius
    Second attempt scheduled after 2 PM local on Saturday. Dun no if original cast of dignitary official watchers will re assemble. Those who do will get the good seats.
  12. ETC(SS)
    6,545
    GODspeed Artemis!
    It would be really REALLY cool to test two crew capable rockets with enough stroke to get to other rocks.
  13. tochatihu
    9,046
    3,528
    2001 Prius
    Back to the barn until October sometime. Somethings need to be reset that can't be done on the pad. No hydrogen testing happens inside Vehicle Assembly Building, for Hindenbergish reasons.
    People elsewhere who post as if they know things suggest that the solid-fuel sidesticks are past their 'best if used by' dates. I guess we'll find out...
  14. bisco
    49,402
    elon's laughing
  15. tochatihu
    9,046
    3,528
    2001 Prius
    With 6 weeks pause in FL, I expect media attention will move to Starship in TX. Is it standing ready to make big methane fire? Which type of fire will that be? Oh, the clicks many are.
