Nasty sound when reversing and then coming to full stop
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by OptimusPriustus, Oct 14, 2024.
  1. OptimusPriustus
    OptimusPriustus Active Member
    328
    137
    Finland
    Sound comes from the rear end. It’s very ”dry&rusty” creak. There are so many joints and bars of all kind. What might be most probable joint that i need to lube or clean to get rid of that embarrassing sound?
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Does the noise change at all when you're using the brakes or not using the brakes?
  3. OptimusPriustus
    328
    137
    Finland
    If i apply brakes very very gently sound is weaker
  4. PriusCamper
    12,064
    4,896
    If you're DIY I'd inspect the brake calipers and pads for uneven wear as well as make sure the backing plate isn't rubbing... But if you aren't DIY and have to depend on a shop I'd be careful about who you take it to because at most shops the fastest most dishonest way to make money off a car that doesn't need any work is to BS the owner into forking over $1K to do all the brakes because it only takes an hour and the markup on pads and rotors is extreme.
  5. Mendel Leisk
    40,584
    How the rust, say on the rear, solid-axle beam, trailing arms, springs/shocks? Finland uses a lot of road salt?
  6. OptimusPriustus
    328
    137
    Finland
    shortly put: it’s everywhere. The rust i mean. That is why i have no idea where to start
  7. bisco
    51,155
    disks might be rusty
