Nav gets disoriented
Discussion in 'Gen 2 Prius Main Forum' started by ammiels, May 18, 2005.
  1. ammiels
    ammiels New Member
    121
    brewster, ny
    put in the motion delete switch with no probs last year. This year I
    had the new "CD" switched on my G2 and the nav takes a long (up to
    several minutes) time to re orient after motion switch used and then
    turned back on. I understand there is a menu to see how many
    satellites nav sees at the time, but I can't find it. Or any other
    advice appreciated. TIA, Peace, Ammiel
  2. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    If you have the GPS icon in the upper left corner of the map, it has enough satellites. To see the actual satellite signals, you have to put the MFD in diagnostic mode. There are two ways to do this.
    Method 1
    (a) Start the HV system.
    (B) While pressing and holding â€INFO†switch, operate light
    control switch, OFF " TAIL " OFF " TAIL " OFF "
    TAIL " OFF.
    © The diagnostic mode starts and the service check screen
    (â€System Check Modeâ€) will be displayed. Service inspection
    starts automatically and the result will be displayed.
    Method 2
    (B) Switch to the â€Display Check†screen.
    © From the display adjustment screen, touch the corners of
    the screen in the following order: upper left " lower left
    "upper left " lower left " upper left " lower left.
    (d) The diagnostic mode starts and â€Service Check†screen
    will be displayed. Service inspection starts automatically
    However, I don't think it is the satellites that is the problem. Probably the programming just takes longer to readjust. Remember, disabling the speed sensor intentionally introduces a problem: the car can't detect that you moved. GPS is used for recalibrating your position, not for foot-foot movement.
  3. KTPhil
    KTPhil Active Member
    1,379
    Don't know how many times it has to be said, but by disabling the speed and turn sensors with a Nav switch, you eliminate the ability to dead-reckon, which drastiaclly reduces local accuracy of the Nav system. GPS alone, even with max sats in view, will be inaccurate if you make many small motions (turning and small distances).
  4. DanMan32
    3,799
    27
    Tampa Bay, FL
    You can't disable the turn sensors. It is a solid state gyroscope and I believe it is built into the NAV ECU.
