Nav Night Screen & XM Install
Discussion in 'Gen 2 Prius Audio and Electronics' started by Anim8or, May 23, 2004.
  1. Anim8or
    Anim8or New Member
    I just installed XM & everything went perfectly & worked great. Jon's DVD was GREAT! However, I just noticed that my Nav screen no longer dims when the lights are turned on at night. Is there something that I could have done or is this just a coincidence & the Nav display has a problem?
  2. Raenstoirm
    Raenstoirm New Member
    179
    Maryland
    Did you bump the little rolly switch next to the EV button space? Also someone might have bumped the option in the nav screen. "display" near the top it should say "night mode" or something similar.
  3. Anim8or
    Anim8or New Member
    I've checked the night display options and tried to change them with no result. I'm not sure what the rolly thing is. Where is that?? Thanx for your response.
  4. Anim8or
    Anim8or New Member
    Oh, THAT rolly thing. Who knew it did that to the screen setting! Thanx. Duh!
