Nav Nightime Mode Malfunction
Discussion in 'Gen 3 Prius Audio and Electronics' started by donee, Apr 1, 2011.
  1. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Ok, since I went in for a "free" Oil Change Navigation does not go into nightime mode (dark colored background). What did they mess up to get me back in there to charge Toyota (waranty?) to get fixed?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Check the dimmer dial (on the left side of the dash to the left of the steering column), make sure it is not clicked up so when you turn your headlights on the dash lights don't dim. That will keep the nav in day mode. You can also click the display button on the lower right of the nav (a physical button, not a screen button) I think it brings up an option for day night mode on the display.
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    My guess is a "full up" dimmer switch. I doubt someone at the dealer is going to poke around changing settings just for the owner to return & complain. I suspect the original mechanic would have to eat the time to fix the problem.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    +1 on the dimmer.
    Tom
  5. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Yep, that was it. The guy must have turned the dimmer wheel all the way up to see what he was doing to reset the maintenance required warning. Thanks !
  6. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Your welcome, glad it was that simple :)
