Nav Override
Discussion in 'Gen 2 Prius Main Forum' started by mktbob55, Jun 9, 2007.
  1. mktbob55
    mktbob55 New Member
    <span style="color:#000099">How to Override Toyota Prius Navigation Gray out
    The Toyota Prius (with navigation package) disables access to several useful navigational functions when the car is moving. While this motion-lock safety feature is OK for a driver alone, there are times when you may want your passenger to have the ability to enter addresses and get directions while in motion. If the steps below are followed, the NAV functions will be available until you shut down the car.
    Steps Push MENU Button on bezel.
    Tap the VOLUME soft button.
    Tap top left of screen then the bottom left, then top left again, and finally the bottom left again. Be aware that you will receive no visible or audible feedback while doing this.
    If the above is done correctly, the Service Menu will appear.
    Press and hold the Override soft button until it beeps and is highlighted.
    Press the BACK button to return to your nav screen.
    Tips These steps must be repeated if the car has been shut down since the last procedure.
    The steps have been reported to work only for North American Prius models through model year 2005 "ONLY"
    The steps work on a North American Highlander Hybrid 2006 exactly as shown.
    The steps work on a North American Camry Hybrid 2007 as shown above with minor cosmetic differences.
    This does not work if you upgrade the navigation DVD to 6.1.
    Warnings [edit]Be safe -- only use this when a passenger can safely input addresses; otherwise, please pull over and do this from the side of the road or in a parking lot. </span>
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I think these are a sticky somewhere, but some may not know about them. But be aware this Easter Egg only applies to the '04 and '05 Prii.
  3. whitespider
    whitespider Member
    101
    Lansing, FL
    Wonderful trick. I followed it mentally since I have been aware of the service screen. It's too bad an 07 can't have this.
