NAV Question - Entering specific route.
Discussion in 'Gen 2 Prius Main Forum' started by rhanson739, Nov 25, 2008.
  1. rhanson739
    rhanson739 is loving the new Prihicle
    50
    Eastern N.C.
    Hi -
    I'm pretty new to the 08 Prius, and completely new to Nav systems. So far, though, "Lola" has done pretty well for me.
    Question: Is there any way to enter, or pre-designate, a specific route without relying on Lola's three routes?
    Let's say that I have a detailed paper map of an area, and I want to take back roads without ever referencing that map. Is there any way to surf around the Nav systems map before driving, and pick "this road", "that turn", and other guidance points? I'd like to lock in that route, and then just sit back and drive.
    Thanks!
    Rob
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Not directly. Automobile nav systems are not like those on boats and planes, where you always link a number of waypoints into a route.
    You can accomplish something similar by using multiple destinations, and linking one to the next. Jill (that's her real name, according to the data file) will still give you three choices, but the choices will all route through your intermediate destinations.
    The bad thing is that you cannot save these routes. You can save the waypoints and reuse them, but you have to select each destination every time and add it to the current route. I hope Toyota changes this in a future version.
    Tom
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    The best way to accomplish that would be to enter by the various "intersections" I think.
    What you might do is do the usual point to point map...then go back and enter any changes as additional way-points...depending upon the route that may work well..or it may not.
    So, if I'm going from home to Bob's Big Boy I'd enter as a specific location...pick the one of the 3 routes that's the closes to what I really want to take and hit Enter/Guide.
    Now if it takes a left at HWY 1 and you want to go all the way up to HWY 2 instead just go back and hit "Intersection", enter the HWY 2 and whatever your starting road is...it'll ask if you want to ADD or Replace...Add it b/w home and Bob's. Check to make sure it routes you as you want it. Do that for each intersection, as necessary, along your route.
  4. qbee42
    18,058
    3,073
    Northern Michigan
    Also make sure that the additional destinations are added in the correct order. You can shift them around if necessary.
    Tom
  5. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    I've found it is even better to add the points a few hundred yards before or after the intersection.
    If I add the destination on top of the intersection, then the vioce prompts dont tell me if I'll be turning as I approach the intersection. It simply indicates that I am approaching my destination.
    By adding the destination before or after the intersection, the voice prompts are able to indicate what I am supposed to be doing when I approach.
  6. rhanson739
    50
    Eastern N.C.
    Thanks for all the pointers! It doesn't sound like a particularly elegant process, but I'm sure I'll get used to it over time.
    A couple of Sundays ago, we took a nice, backcountry cruise, but we had to have the passenger plotting the route on the Gazetteer, while the Nav gave us more insight into some of the roads and intersections.
    I'll try it this way...
    Rob
  7. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    I actually observed what looked like learned behavior on my NAV. There is this route that I've taken a number of times, and one time I ignored the NAV instructions and took an alternate route. The next time I entered the same destination, my alternate route showed up as one of the 3 options.
    Another really neat function is "Detour". You're following a route, and get stuck in traffic. Give the voice command "Detour" (it actually understands me on this one), and the NAV trys to find an alternate route. This has pointed out a number of alternate routes that I was unaware of, even in an area that I drive regularly.
  8. A Prime Factor
    A Prime Factor Formerly "I want my PHEV"
    340
    171
    Madison, WI
    I can confirm that it does this. I have been taking a weekly class located in a part of town I'm not too familiar with. So I programmed the NAV with the address and followed one of the 3 given routes. I wasn't entirely pleased with that route, and wanted to take a different street, but it wasn't one of the 3 choices. So, in future trips, I started by choosing the most similar route, and then deviating. "Hillary" just adjusted her instructions to get me there. I continued to use the NAV each week because my destination is far down a winding road with a lot of similar-looking buildings. This winding road comes after a couple of turns on other twisty roads once I'm off the main street.
    One time, though, I noticed that my preferred street was now one of the 3 choices. So I chose it, but Hillary instructed me to turn off the main road (the start of the twisty part) a few blocks earlier than I had been. I ignored her and she then instructed me to turn at the usual place. The following week, I was able to choose the preferred street as one of the 3 choices, and when I got to the early turn, she said nothing. Then I reached the later turn, where I had turned before, and she said to turn there.
    She seems to know I like that route.
  9. A Prime Factor
    340
    171
    Madison, WI
    A word of warning if you do this. I took a trip to Michigan last summer and didn't want to drive through Chicago. I picked a route that went around Chicago. I chose a point on the interstate as my first destination so that the NAV would have to take me around Chicago, and from there I said I wanted to go to [my final destination]. It worked great. Once I reached the first point, my final destination became my new destination.
    But on the way back, I tried to do the same thing. I set that same point as my initial destination, and then home from there. As I approached the intermediate destination, something weird happened. "Hillary" told me to exit the highway. I was confused, but did it anyway. She had me turn around and head the opposite way on the same highway. Then I suddenly figured out what was happening. The point on the highway (remember this was an interstate) could only be reached from the southbound side. Until I turned around, I couldn't reach the "destination."
  10. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Re: the navigation voice names, the Prius uses Nuance's RealSpeak to provide the voice. The US English voice is Jill, but other countries have their own voices and names -- the link has a list of the supported languages. I've been wondering -- do Priuses in other English-speaking countries use the US accent, or do they have the localized accents like Karen (Australia) or Emily (UK)?
