Nav Routs Less Than Good
Discussion in 'Gen 2 Prius Main Forum' started by priusofpa, Jun 17, 2007.
  1. priusofpa
    priusofpa New Member
    I may have just missed it, but I have not seen any complaints about the routes the Nav gives. I consistently have problems with it trying to take me is convoluted or longer than needed routes. Some are just nuts. Perhaps I don't get it. I live in Phila, if I want to go to Penn State U, it adds 40 to 60 miles on the quick routs and the short route would take twice as long. I had the same thing trying to go to Princeton, which is straight up 95 to US 1. It trys to take you through Washintons Crossing and other places. Yet, on the way back it routes you correctly. Similar problem occur within the city. Anyone else having similar issues. Is there an easy way to add "via" type instructions like Delorme has. I end up having to do a computer map, then driving until the Nav system decides to catch up and go the more efficient way. All this could just be me, but I don't think so.
    Thanks,
    TO
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(pruisofpa @ Jun 17 2007, 06:06 PM) [snapback]463616[/snapback]</div>
    My Garmin did the same sort of thing to me in Altoona Friday although I don't have any avoidances selected. So, maybe it is just a computer problem and not a Toyota problem?
  3. Tideland Prius
    16,125
    <div class='quotetop'>QUOTE(pruisofpa @ Jun 17 2007, 04:06 PM) [snapback]463616[/snapback]</div>
    Check the options perhaps? toll roads, avoid freeways etc etc.
    or maybe someone else in your family put an "avoid" notice over a certain area so the nav avoids it
    that's all I can think of at the moment.
  4. rachmaninoff
    rachmaninoff New Member
    25
    <div class='quotetop'>QUOTE(Tideland Prius @ Jun 18 2007, 02:33 AM) [snapback]463846[/snapback]</div>
    I know the lexus nav has an "avoid uturns when planning routes" option that an be turned off. is there a similar option on the prius nav?
    one trip i make a few times a year is about 3 and a half to 4 hours long (thankfully i know the route) the nav would have me travel 45 minutes out of my way to avoid a simple uturn. there is an exit off of a highway that only goes east, meaning there is no west exit from that direction on to that highway. a simple UTurn on the next exit less than a mile down that highway saves me 45 mins on my overal trip. it seems odd that the computer in the nav system can caluculate the actual fastest route. 45 minutes is an unacceptable detore and really worries me when i travel places i dont know, just how far out of the way is my nav taking me.
    for those interested in the specifics. the trip i take is from maryland to northen new jersey.
    The fastest route once in NJ is 95n (turnpike) to exit 11-GSParkway to 78 east, take next exit uturn 78west to 24 to 287 to 80 to destination. The nav system wants me to take 95n(turnpike) all the way up to 280 east then 80.
  5. Swanny1172
    Swanny1172 New Member
    666
    The purpose of a GPS nav system is to get you where you are going without getting lost. If you already know how to get where you are going, why are you bothering to use the nav system?
  6. aaf709
    3,862
    2022 Prius Prime
    Once I had a bad problem with the navigation. I was told to make a legal U-Turn and take another road. I had no avoid settings. It turned out that I was on the edge of a military base. The NAV system wanted me to avoid it, even though that part of the base was OK for travel on.
  7. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    <div class='quotetop'>QUOTE(Swanny1172 @ Jun 18 2007, 10:01 AM) [snapback]463965[/snapback]</div>
    Another useful purpose of a GPS nav system is it's ability to keep you informed of estimated time of arival, or estimated time remaining, both for the entire trip as well as for individual stops along the way.
    I frequently use my nav for this purpose even when I know exactly where I'm going and how best to get there.
    The problem arises when the route I intend to take (the route I know is fastest or shortest) doesn't coincide with the route the nav computes. The the estimated times are far enough off to render them useless.
    I can usually encourage the nav to compute the route I intend to use by looking at where it heads off in the wrong direction, and adding a waypoint somewhere beyond that point on the route I intend to take.
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    It is definately worth some time to fine-tune the various NAV options available.
    For instance, as someone mentioned above, it may be set to avoid toll roads or even to avoid interstates. Also, the estimated times can be way off. Some 60mph rural highways are considered "side roads" by the NAV and time estimates will be based upon 35mph average speed. You can reset the speeds for the 3 types of roads. Even the Interstates are defaulted to 55mpg I think.
    I once had mine accidently get reset and it was constantly steering me off of the interstate to weird side routes until I corrected the defaults.
    That said, even once you get it reset it will not always give you the route you prefer. If you have the options set to 'reroute' you if you get off track you can often start off the direction you want to go and it will then figure out that there's another option and reset itself to guide you along that route. Likewise, you can wait to program it until you're on your way on the primary route you intend to take.
    All in all, once you work through it's quirks, the NAV is pretty decent...but you still have to pay attention.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Ours does pretty well, but as Evan suggested, it worked a lot better once we changed the speed settings for the back roads. You can force routes by adding intermediate destinations (waypoints on some systems) and linking them together.
    Tom
  10. efusco
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(qbee42 @ Jun 18 2007, 10:44 AM) [snapback]464001[/snapback]</div>
    Excellent point Tom, I've had to do that a few times myself, particularly on longer trips when I wanted to go through certain cities.
  11. qbee42
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(efusco @ Jun 18 2007, 11:50 AM) [snapback]464005[/snapback]</div>
    I wish the Prius NAV system gave us a way to save these routes. We do that all the time with our marine GPS system. With the marine system, you create a bunch of waypoints, then link them together to create a route. The routes and waypoints are named and saved in the system's memory. You could do the same sort of thing with the Toyota system if there were just some way to save the routes.
    Tom
  12. ohershey
    ohershey New Member
    632
    <div class='quotetop'>QUOTE(Danny Hamilton @ Jun 18 2007, 10:39 AM) [snapback]463993[/snapback]</div>
    I have used SEVERAL different GPS NAV systems, and they all seem to have the same failing. Basically, a universal system just can't be as good as a local driver at figuring out the fastest route in a given area. My NAV system habitually sends me down US101, when everyone knows that US101 is really a very long parking lot in my area. I COULD get around it by setting a preference to avoid major highways, but the every time I went somewhere else it would be a big mess. I just drive the route I want, and eventually the system figures it out.
    <div class='quotetop'>QUOTE(qbee42 @ Jun 18 2007, 12:13 PM) [snapback]464073[/snapback]</div>
    That seems to be the big complaint with factory NAV systems (not just Toyota's). The aftermarket guys need to go after your business with features and regular updates, while the factory systems basically rely on all of our desires for a clean, integrated install to sell the system for them.
  13. Ken S
    Ken S Member
    191
    Pittsfield, MA
    <div class='quotetop'>QUOTE(Swanny1172 @ Jun 18 2007, 11:01 AM) [snapback]463965[/snapback]</div>
    Because sometimes you know how to start out but not get to the final location.
    For a long time a lot of nav systems didn't think that Florida's Turnpike existed and would route you up 95 and then over to get to Orlando from SE Florida. Yes, you would get there...but it would take at least two hours longer to do it that way.
    For what they charge...it should work far better than it does.
  14. Stairman
    Stairman New Member
    42
    Another reason any GPS may give you a less than optimum route is the lack of computational horsepower. The routing algorithm has to be able to give you a route in a reasonable time with limited processing power. If it analyzed every possible route it would take way too long.
    While I've had my Garmin unit take me on inefficient routes, I've also had it find new tricks in parts of town I thought I new.
  15. hschuck
    hschuck Member
    385
    17
    bay city, ca
    <div class='quotetop'>QUOTE(Ken S @ Jun 18 2007, 04:00 PM) [snapback]464334[/snapback]</div>
    You can have it both ways.
    Put in your final destination. Drive your preferred route until you get to where you want help; the nav sys will continue from there. You can suspend or resume guidance (menu button on bezel) or simply ignore guidance until you want it.
