Nav screen questions
Discussion in 'Gen 3 Prius Audio and Electronics' started by tnt71, Mar 12, 2011.
  1. tnt71
    tnt71 Junior Member
    I have a 2011 with the sunroof/nav package. Two questions:
    First, the screen never seems to change to night mode. I read the manual and it has an option in there that is not on the screen when I hit the "display" button. The day mode is too bright at night.
    I also noticed that if I press the setup button the screen continually defaults back to the setup screen about 20 seconds after I hit another button, like audio or nav. It continues to do this until I shut the car off and restart it.
    Thanks in advance for the help.
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    You have the dimmer switch (located on the left side of the dash) set to daytime mode. Rotate it downward to unclick it.
  3. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Odd. Are your headlights on while when you hit the display button?
    Day mode button will be near the top of the nav screen if it's working.
  4. CoyoteBlue
    CoyoteBlue New Member
    Maryland
    - Do you also have a very bright MID and instruments at night? You probably have your dimmer clicked off.
    - The audio screen is always temporary. The Nav will go back to the Map, Dest, Phone, or Setup screen (whatever was last selected before Audio) after 20 seconds. Pressing MAP should take you completely out of setup.
  5. Joe166
    Joe166 New Member
    720
    96
    South Florida
    That is true, but you can change that default setting and make it stay on the audio or whatever screen you change to. It is quite easy.
