Nav System Announcing Street Names?
Discussion in 'Gen 2 Prius Main Forum' started by NYMama, Aug 27, 2008.
  1. NYMama
    NYMama Junior Member
    17
    Westchester, NY
    Hi everyone, took my new prius out for a 10 mile ride today to a local mall. I could probably drive there blindfolded (not a good idea, I know), but I was playing with the Nav system and decided to try it out. I have not read the operating manual yet, so I'm not sure if I had it set correctly.
    Anyway, the Nav system never once announed a street name when it was time for me to make a turn, nor did it announce the Parkway name when I was on the Parkway. All it said was make a right, make a left, make a right, etc. It was even telling me to go right, left, right on a curvy street where there was no intersection with another street.
    So my question is, does the Navigation system announce the street names or highway names when it is time to make a turn on to them? :confused:
  2. dogfriend
    7,512
    1,188
    Carmichael, CA
    It will say stuff like "continue on I-5 south", but I don't remember it announcing the name of the upcoming street. It usually says something like "left turn in 500 feet".
    I don't use guidance all that often, but I have found that its a little bit passive-aggressive when I have used it. For example, the last time I used it, I knew the area reasonably well, but did not recognize the street that the business was on so I entered the address as the destination. During the drive, on the freeway, about 5 miles before the actual turnoff, it started telling me to take the next off ramp. I knew it was too early, but thought maybe it knows something I don't. As soon as I exited the freeway, it started to tell me to get back on the freeway. Doh!
  3. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    I don't know whether the distinction is built-in, but I think it only announces Interstate Highways and U.S. and State Highways. I don't believe it tries names, but only numbers.
  4. kimgh
    kimgh Member
    297
    San Jose, CA
    It will say "exit to i880 north is on the right," but does not give street names, unfortunately. The display will give the name of the street you are on. What I'd like is for it to also (or instead) give the name of the next cross street coming up, like my old Garmin did.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It doesn't announce street names, unless they are interstate highways. It does tell you of an upcoming turn, then chimes to announce the actual turn, but doesn't give names.
    On the highway, it will say things like: "Right turn onto I-75..."
    Tom
  6. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    The really weird part is the system is capable of saying the street name, because when you enter a destination via "address" voice command, the system repeats the street name it matches in the database. So it can say them all, it just doesn't for turn guidance. Intersting .
    I have surprisingly good results with all types of voice command, including the address feature. It's really effective, but a little unusual to do at the first time.
  7. Joekc
    Joekc Member
    265
    16
    My NAV system doesn't say "I suck" either, but if it did at least it would be accurate for once. :mad:
  8. qbee42
    18,058
    3,074
    Northern Michigan
    I like mine. It works well for me. That must be why there are multiple brands of almost everything. Sorry it doesn't work well for you, since it makes for an expensive paper weight.
    Tom
  9. thomash
    thomash New Member
    Langhus in Norway
    My NAV does not say the street name here in Norway, but when I went on holiday in Denmark this summer it said the name on several main streets, not the number but real name. It sounded a bit strange because the NAV usually speaks norwegian but the street name was spoken in danish....
  10. Joekc
    Joekc Member
    265
    16
    Unfortunately only one brand was available in my Prius. At the time I bought the car I really had no option -- it was take it or don't take the car. That said, I get far more funtionality from my $300 Garmin Nuvi than I do from the $1000+ (?) NAV system. It may just be my area of the country, but I frequently find roads that have been in place for quite a few years are simply not there (I have map v. 7.1) So where am I? A lot of times, apparently, driving in a nice green field. I could say other things but I really don't want to start a big argument about the NAV system. (We've had many!) People seem to either love it or hate it. To those who love it, I say great! It's just a big disappointment for me.
  11. YoungOrganist
    YoungOrganist New Member
    Bahstahn MA
    2002 Prius
    My cheapo garmin announces street names and gives better directions...
    But I'm a bit fond of the factory nav because it's much more convenient and faster to program, and a much bigger, nicer map to look at than the garmin. Though I can't get over the facts that it doesn't show one way streets in the city, and it fails at giving directions that make sense.
  12. Sarge
    Sarge Senior Member
    1,311
    767
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    The Toyota NAV also announces exit numbers in addition to US Interstates.
    Mapping data does vary from one region to another, if you are in a metropolitan area, coverage should be very good. If you are in a rural area, maybe not so good.:(
    I've been using the NAV in my car for 2.5 years in the Toronto area and almost always set a destination (mostly for entertainment, since I know my area fairly well, but I like to know my ETA ;)) and the directions are overall quite accurate. In certain areas, it seems to bias toward main streets vs. residential a little heavier than I would like - even with "Short" route selected - but whatever...
    I do second 9G-man's comment that since the computer already has the text to speech engine to echo back the street names during the 'Address' command, this functionality should be available as an option that can be enabled for guidance as well... By no means is it a life or death feature, but a "nice to have". Version 8.1, perhaps? We can dream... :rolleyes:
  13. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    This is because Toyota is using Navtech for the Prius nav. Navtech is the worst data GPS street data provider on the planet.
  14. Sho-Bud
    Sho-Bud Member
    190
    Amsterdam, Netherlands
    And so does Garmin...
  15. kimgh
    kimgh Member
    297
    San Jose, CA
    I'm betting that EVERY US street database, whatever the manufacturer, starts with the Tiger database maintained by the U.S. Census Bureau. I assume there are a bunch of value adds put on by the various companies that make GPS gear or street maps (DeLorme comes to mind, and of course Yahoo and Google... And Navtech). But it simply would not make sense to roll your own from scratch when that beautiful, FREE, Tiger database is there for the downloading, already paid for by our taxes.
    The point being: If the Tiger database is wrong, Navtech (or Google or ...) may not ever know it unless the mistake gets reported. I bet every provider of map databases has their own list of corrections, so some might be correct where others are wrong.
    And of course, the Tiger database is updated continually, I believe. It's not an easy problem to maintain a database of this size. So the amazing thing is just how accurate they are most of the time (even NavTech...)
  16. 9G-man
    1,273
    194
    Atlanta, GA
    No way, no how, not by a longshot.
  17. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    I and most of the nav uses in North America would beg to differ.
  18. acidburn517
    acidburn517 New Member
    35
    PA moving to WI
    My Prius NAV is lazy. It picks a route and tells me to find my way from where I am to the start of the route it picks. It doesn't alway start to direct me from wherever I am. Nevermind the fact that the whole point of me asking it for directions is because I'm lost and would probably get even more lost trying to find the route it wants me to follow. It also takes the looooongest time to recalculate when I miss a turn and goes cracy if I don't go the direction it wants me to go.
    I would take an el cheapo garmin any day over this (and actually do use one). I honestly didn't want it but like some others, it was either take the car with the NAV you know you'll hate or no car at all.
  19. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    You can beg all you want :D
