Nav system destination problem
Discussion in 'Gen 3 Prius Audio and Electronics' started by mainerinexile, Apr 21, 2010.
  1. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    How does one tell the Nav system that you've arrived at the programmed destination? Unless I manually delete the destination each time when I get there, the system will try to guide me back to the same destination indefinitely, long after I've been there and gone. Am I missing something automatic to get it to realize that "we've arrived"?
    Thanks!
  2. W7ZR
    W7ZR Junior Member
    Arizona
    On my 2010 I do not have that problem. Once I arrive at destination it tells me I have arrived and it is terminating route guidance. Perhaps something in your settings.
  3. mainerinexile
    403
    73
    Maine
    Thanks, this gives me something to look at. Perhaps is a micro-location error problem. For example, I just noted that based on the map guidance, the Nav thinks my home address is #4, rather than the actual #6. Likewise, if I pull into a parking lot for the destination, the Nav may not think I'm quite there yet. This might be part of the issue--getting close to the destination probably isn't good enough.
