Nav System example
Discussion in 'Gen 2 Prius Audio and Electronics' started by rcsron, Aug 23, 2008.
  1. rcsron
    rcsron Junior Member
    San Diego
    I would like an example of how to enter an origin and a destination of the Nav system.. JUst a basic procedure of how the system works..
    Thx Ron
    Warner Springs Ca
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You don't enter an origin. The NAV system calculates from your current position, and recalculates in real time.
    To enter a destination, press the DEST button on the side of the MFD. The destination screen comes up, from which you can select how to enter the destination. You can pick from saved destinations, previous destinations, an address, an intersection, from the map, or by entering GPS coordinates. If you have an existing destination selected, you are given the option of replacing that destination or adding the new destination to the route. After that is settled, if you select "guide" the system will offer three different routes: quick1, quick2, or shortest. You select one of these and guidance begins.
    Tom
  3. aaf709
    3,862
    2022 Prius Prime
  4. davidtm
    davidtm Member
    180
    TJ'ville
  5. Sarge
    Sarge Senior Member
    1,302
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Just to add to Tom's clear and detailed answer, if you would like to determine a route from a specific "origin", simply enter that origin as your first destination (effectively as a waypoint), and your true destination as your second destination.
    The routing, distance and instructions between destination 1 & 2 will be what you are looking for...
