NAV ?: That number does not exist on that street!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by PriusMatt, Jul 13, 2007.
  1. PriusMatt
    PriusMatt Junior Member
    40
    Out of the 10 times or so that I have tried to enter an address that I need to go to, I'd say at least 5 of those times I get a message that says something like "That number does not exist on that street." I have later tried those same addresses on Mapquest and they seem to exist there.
    What gives? And how can I work around this problem?
    Thanks.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    If you can't use a street number, then enter the destination via map view, or use a nearby intersection.
    Tom
  3. b777
    b777 New Member
    24
    Try entering the street first then enter the number. I have had this same problem and tried this method and it worked several times.
  4. Inches
    Inches Member
    117
    San Mateo, CA
    If you enter the street first then it will give you a number range. Make sure you keep your St, Blvd & Ave's straight.
