Nav wont recalulate route when don't follow initial directions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aly, Sep 18, 2007.
  1. Aly
    Aly New Member
    Lomita, CA
    I have an 05 Prius with the Blue Tooth/Navigation option and just last month the navigation computer started giving me issues. I will enter a destination and the computer sets up route but if I decide to take a different route (i.e. shortcut to the freeway), the computer will not update the route to accomodate my new location. The only way I can get directions from the nav system is if I get back to the original planned route.
    Has anyone experienced this issue before? Are there any know fixes? I don't really want to go into the service center just for this issue since I'm not due for my next servicing until december.
    Aly
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Have you checked to see if the settings have changed? In the setup area you have to select "auto reroute" (or something similar).
  3. Aly
    Aly New Member
    Lomita, CA
    Thanks. I'll check that after work today.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Also, did you enable guidance at the start of the route?
    Tom
