NAVIGATION ERROR
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lpf, Jun 17, 2021.
  1. lpf
    lpf Member
    113
    33
    Greece
    Prius 2007 problem:
    Navigation DVD works OK, checked - System check done, NAV is OK, no fault codes.
    Map DVD is correct. I purchased an original map DVD (according to Toyota Europe code is OK,
    checked, latest update). I have the message that you see in first picture. Any ideas? Any help? Thanks.
  2. dolj
    dolj Senior Member
    7,648
    3,858
    Wellington, New Zealand
    The third screenshot does not show any disc information.
    I suspect the DVD is damaged in some way and the DVD player is unable to read the DVD.
    Have you tried this DVD in another reader?
    Have you tried a different DVD in this reader?
  3. lpf
    lpf Member
    113
    33
    Greece
    Map DVD is brand new. I will try to clean the lens of the DVD player. Yes my previous DVD, version 2007 was working.
    Is there any possibility to reset something?
  4. dolj
    dolj Senior Member
    7,648
    3,858
    The would have been my next suggestion, too.
    Not that I'm aware of.
    Did you insert the new DVD with the correct side up?
    I presume you've tried your old DVD in the player and that is still working ok?
    #4 dolj, Jun 18, 2021
  5. lpf
    lpf Member
    113
    33
    Greece
    Probably I know the correct side...
    It's very strange, everything is ok but nothing is working.
  6. lpf
    lpf Member
    113
    33
    Greece
    Problem solved: 12V battery disconnected for about 3 minutes. Then DVD player scanned the map disk and recognized it.
    dolj likes this.
  7. Landon51
    Landon51 Member
    190
    63
    US
    Put the disc in a desktop/laptop and check it it's DVD-R instead of DVD-RW.
  8. lpf
    lpf Member
    113
    33
    Greece
    Read my latest answer...
