Navigation Help Please
Discussion in 'Gen 4 Prius Main Forum' started by DBLXX, Apr 28, 2016.
  1. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    Used the Nav for the first time this morning and it worked great - only problem was after about 1 minute it would automatically revert to the HOME screen on its own.
    Only way to get back to Nav was APPS then NAV - but then only stays for a minute then back to the HOME screen.
    Any help?
    TY
  2. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    I sort of recall a setting for that. I'll bet that if you scroll through the setup menu, you will see an obvious choice.
  3. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Tap the map. Not sure about settings.
  4. ATHiker
    644
    560
    Massachusetts
    Four Touring
    One thing to try:
    Apps - Setup - General - Scroll Down - Auto Change to Home Screen (uncheck, I think)
    Good luck -- there are a lot of buttons to push on this machine. Last I screwed around with this was 3 months ago so I am going to resist the temptation to test whether or not these are the ones to address your issue!
  5. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    That was it. You're a life saver. Thank you.
