Navigation Location Question
Discussion in 'Gen 3 Prius Main Forum' started by jvtucker, Aug 6, 2009.
  1. jvtucker
    jvtucker New Member
    Washington, DC
    Ok, so I'm sitting in my car and need directions on how to get home, so enter the address and once I find my way to the correct freeway, want to cancel the navigation because I can get on home on my own now.
    But how the heck can I make it stop giving me directions? The voice drives me nuts and turning off the sound isn't enough for me.
    Does anyone know how to cancel a trip mid-way through?
  2. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Not in my car now but I think you hit the DEST button and then on top there is a button for destinations or something like that, you click that and it says something along the lines of are you sure you want to delete destination
    Sorry but I'm not near my car now to go check for the exact button and wording of each button...
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  5. jay_man2
    1,246
    143
    Manassas, VA
    Seems kind of convoluted just to pause guidance. :confused:
  6. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Thats not to pause the guidance, that is to completely delete the current set destination. He had askedhow to cancel so cancelling to me is deleting the destination but in his situation pausing it works just as well if not easier and faster.
  7. jay_man2
    1,246
    143
    Manassas, VA
    I have Home and Work as pre-set destinations, and use those presets on a regular basis, whether to have the XM NAVTraffic tell me if there's any issue on the route, or to get me started in the right direction like the OP. The pause guidance voice command is a great easy way to stop the voice and turn by turn guidance once I no longer need or want it on.
    EDIT: I guess as a result of the way I use the NAV I never thought in terms of deleting a destination. Even on destinations that aren't pre-sets I just pause guidance. But then the next time I program a destination I believe the NAV asks if I want to add the new destination to the routing, or replace the old destination, and I have to respond with replace.
  8. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Yup, that's why I guess I just got in the habit of deleting the destination right away instead of suspending it in my 2006... "pay me now or pay me later" lol
  9. MaggieMay
    MaggieMay Active Member
    534
    68
    Gloucester, MA
    You can pretty easily delete the destination. Once I know where I am or how to get theah from heah, I delete it. I believe pausing it keeps it in the system - which could be useful for a future visit - but not very often.
  10. IraS
    IraS Member
    165
    50
    Austin, TX
    Deleting a destination and pausing guidance only affects the turn by turn directions.
    Pause Guidance, either from the voice command or from the Route screen, turns off the turn by turn directions, but leaves the destination programmed into the guidance system. You can resume guidance to that destination at any time.
    Delete Destination, again either from the voice command or from the Destination screen (press Del. Dest on the Destination screen) removes the destination (either one or all) from the guidance computer. It doesn't remove it from permanent memory. If the destination came from a predefined destination (i.e. Home or preset destinations 1-5) it is still defined, just not in use. If the destination came from your address book, it is still there. Also, the destination will still show up in the Previous Destinations list.
