Navigation Screen Display Color Issue
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by blueprius2013, Feb 28, 2019.
  1. blueprius2013
    blueprius2013 New Member
    Hawaii
    2013 Prius v wagon
    Prius screen picture.jpg Prius screen picture.jpg I took my 2013 Prius v (wagon) in for service a couple weeks back. They did the recent recall update. The very next morning my navigation screen began to display as a white background when I turned on my car. After a few seconds would switch back to normal color. Over the last two weeks (it is back in the dealership for the second time with the issue), it now has the white background for as long as 10 minutes before it switches. It continues to get worse. My daughter says "Mom, the colors are inverted". Has anyone experience this?
    #1 blueprius2013, Feb 28, 2019
  2. Air_Boss
    Air_Boss Senior Member
    3,941
    1,079
    New Yawk
    Is Contrast adjustable? Could just be that.
  3. whitmanrf
    whitmanrf Junior Member
    23
    Miami
    Contrast IS adjustable but adjusting it does not bring the white blown-out background back down to normal. Sometimes takes a few minutes and it corrects itself but the problem returns.
  4. Air_Boss
    3,941
    1,079
    New Yawk
    Seems to be temperature dependent, then. Was the head unit removed to to the service?
  5. Chris Ruano
    Chris Ruano New Member
    Santa Monica
    How about when it goes blank after you drive the car for 20 minutes and then goes blank.even the back camara don’t show anything
  6. Smoovechaos
    Smoovechaos Junior Member
    This just started happening to me. The screen colors are inverted. Mine is no longer on warranty.
    Can you share if you fixed yours or how?
    Thanks!
  7. fhqwhgad
    fhqwhgad Junior Member
    I'm having that same issue as well... the display starts with that inverted color, and stays that way for some time, up to about 10 minutes for me as well. Sometimes it switches immediately, but that period in which it's inverted can vary widely and randomly... I would also like to know if anyone else has had this issue and has resolved it!
  8. HawaiivGuy
    HawaiivGuy On the Way
    27
    Hawaii
    2013 Prius v wagon
    Started happening to is about two months ago. We moved “up country” about a year ago; temp nightly average about 70f in garage. Display goes normal after about 1-2 minutes. 569518AE-9D8F-4548-A9D7-F9DFCEC99D69.jpeg 4E9E4511-924F-4182-A659-1B8E9BF92E80.jpeg
  9. PriusVT
    PriusVT Junior Member
    Vermont
    My 2013 Prius 3 now has the same inverted color display problem. Has anyone found a fix for this?
  10. icyrius
    icyrius Active Member
    232
    111
    Florida, USA
    2014 Prius v wagon
    Apologies for the topic switch, but where did you buy the wooden trim panels for your wagon? Thanks
