Navigation Speed Lock Override
Discussion in 'Prius c Accessories and Modifications' started by cduvall48, Apr 11, 2012.
  1. cduvall48
    cduvall48 New Member
    Vidalia
    Just wondering if anyone has installed the Prius Navigation Override Lock on their Prius C yet? If so best place to buy it from and does it work?
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    I don't recall anyone ordered the override for the c. So far only 2 orders for the v.
  3. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    a prius override lock... buying it?? is it some module you purchase and install?
    can't you just snip the wires and install a switch yourself?.. seems to be the cheaper method of doing it.
  4. cproaudio
    2,401
    759
    CA
    Yes you purchase it from the Priuschat shop or from prestigious society or from beatsonic.
    Snipping the wire and adding a switch is not recommended. There's a reason why an override module is required. It has been discussed in a couple of threads. The headunit requires a speed signal to prevent it from switching to GPS based speed signal. Once it switches to GPS based speed signal, it'll take a short time for the headunit to switch back to VSS based speed signal once the VSS wire receives the speed pulse. During this time, flipping the switch will not get the grayed out buttons back. You'll have to wait until the headunit has switched back to the VSS based speed signal before flipping the switch.
  5. SquallLHeart
    826
    247
    San Jose, CA
    hmm.. i see.. looks like they've changed a few things from when i last overrid the older Toyota navi units... i used to manually pulse the VSS signal using a manual switch.. and didn't have many problems with it..
    it's pretty much how hawkmoon77 did it before... so it used to work.. at least on the older models. i haven't looked into what changes they made, if any..
    nice work writing up the 555timer method.
  6. cproaudio
    2,401
    759
    CA
    hawkmoon77 cut the VSS wire and found out that it didn't work. Then he built a 555 timer circuit and it did work. You don't have to buy the override. You can build it yourself.
  7. SquallLHeart
    826
    247
    San Jose, CA
    well, cutting the VSS wire completely definitely wouldn't work.. LOL.. that's why i placed an in-line switch in there.
    but anyway.. the override looks like something i'm well capable of making myself. thanks for posting it up! :)
  8. cproaudio
    2,401
    759
    CA
    When you install it, please post pictures.
  9. orangenerd
    orangenerd Junior Member
    58
    Lawton
    so...any updates? Does this work on the c and how easy is this to install...I am not an idiot, but am not super tech savvy.
