Navigation system does not recognize my DVD
Discussion in 'Gen 2 Prius Audio and Electronics' started by nik8, Apr 1, 2010.
  1. nik8
    nik8 New Member
    Alexandria
    2002 Prius
    Hi All,
    This is my first post on the forum and i apologize for the dumb question but i have a 2002 Prius that i got from somebody else. It has the DVD navigation system ( checked for it under the passenger seat, and it even had the DVD inside it ).
    However, when i select any option on the screen it asks me to insert Navigation DVD.
    Any ideas? I do not want to go to the dealership and spend big bucks on figuring out what the issue is with this..if it works - great! If not - i can live with that.
    Thanks,
    Nik8
  2. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    You might try unplugging the cable from the back of the DVD unit for a minute and then plug it back in. That should cause a reset and hopefully a re-read of the DVD. If that does not work, you might try swapping a disk with someone with a similar year car to see if its the disk that is bad or the player
