Navigation system shutoff?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Pete Tibbetts, Apr 15, 2016.
  1. Pete Tibbetts
    Pete Tibbetts New Member
    Gloucester, Massachusetts
    My 2012 PIP has the GPS nav system and if I want to shut it off before my destination I can't find out how to do it! I can't find anything on it in my Owners Manual either. I do not see a "Del. Destination" to press and I do not have a "Stop Guidance" to press either. Any clues out there?
    #1 Pete Tibbetts, Apr 15, 2016
  2. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Press Dest and "Del. destination". It's saved in "Previous destinations", so you can re-enter it later if needed. I wish they had kept the "Pause navigation" function from the Gen III, it was very useful!
    Wolfie52 likes this.
    52,789
    in the base model, press the options button in the lower right corner, and press stop guidance.
    #3 bisco, Apr 15, 2016
  4. CharlesH
    2,798
    1,166
    Roseville, CA
    The button labelled "Del Destination" has always confused me. It does not delete the destination from your destination directory or favorites or whatever. What they asking is if you want to delete a destination from your active navigation route.
  5. Pete Tibbetts
    I do not see a "Del. destination" button after pressing Dest! any more ideas?
    Thanks.
    I don't have a stop guidance button after pressing the options button, any other ideas?
    Thanks
  6. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    In my 2012 PIP, when a destination has been set, pressing Options brought up a screen and the second item from the top was delete destination. Perhaps you selected Options when no destination was set.
  7. Pete Tibbetts
    Thanks for getting back to me! But the problem is that I do have a destination set and want to stop it, I have not seen any delete destination to press no matter what I do. Any more ideas?
    THANKS!
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    Bisco said in an earlier message that on the Base model, it is called "Stop Guidance", not "Delete Destination". The Base and Advanced models have completely different navigation software.
  9. bisco
    52,789
    honestly, i don't know why yours would be different than mine. we both have 2012 base. i went out and double checked it, i don't know what else to say. hopefully someone else will chime in with another idea, all the best!(y)
  10. Pete Tibbetts
    That did it and THANK YOU!
    Pete Tibbetts
  11. bisco
    52,789
    pleasure.
