Navigation Unit "Unable to read data"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Razorhog, Jan 21, 2009.
  1. Razorhog
    Razorhog Junior Member
    NE Arkansas
    I have a 2006 Prius with 58,000 miles. The DVD navigation system has stopped working - the screen says "Unable to read data. Check if map DVD is correct." It has worked great in the past. The DVD is authentic and in mint condition.
    I take it to the dealership, and the technician determines that the Navigation ECU needs to be replaced, and they say it will cost $5,168.28.
    They were surprised at the cost, and told me to call Toyota customer service to see if they could help. All customer service has done is call my dealership and try to talk to the technician and/or service manager about the problem. This ends up being a game of phone tag, and the technician insists the problem is the ECU.
    I do not believe the Navigation ECU is the problem; I believe it is the DVD reader under the passenger seat. I can put the dvd in and I hear the reader trying to access the data, but it makes the sounds of a failing DVD drive like in a computer. (I am a computer tech and know that sound well)
    I plan on taking the car to another dealer for a second opinion as soon as I can.
    Does anyone have any advice? This is my second prius, (wife loves them) and I drive a 2006 Tacoma. We like Toyota, but I feel like I'm being slapped in the face.
  2. Patrick Wong
    18,200
    6,471
    The navigation ECU is the device located under the driver's seat. The device under the passenger seat is the JBL amplifier (for North American models).
    Since you are a computer tech, if you can figure out how to remove and replace the DVD player within the ECU, no problem. Otherwise you'll have to replace the entire ECU that includes the DVD player.
    Alternatively you might be able to obtain a used navigation ECU unit from a salvage yard.
  3. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    57
    Fullerton CA
    I bet it is the DVD drive itself. And, I'd be surprised if the DVD drive is anything other than a full height 5.25" DVD drive with an IDE interface.
    Before you shell out over 5 clams on that unit, I'd open it up carefully (you're a computer tech, so this shouldn't be hard at all) remove the drive, and put in a replacement drive. Just set the jumper for master, slave or cable to match the older drive.
    If it's an SATA drive, you can buy one of those two.
    I'm betting $50 in parts and an hour or two and you'll be up and running again.
    Let us know how it goes!
  4. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    How much of that is parts, and how much labor? That does sound a bit outrageous. See if you can get the part number from them and shop around, there are a number of online Toyota parts dealers that generally have better prices. If its still high, maybe try Steve at
    http://autobeyours.com
    for a used one. You should be able to get the pertinent factory manual pages for $10 per day from
    https://techinfo.toyota.com/
    and replace it yourself if the dealers labor estimate is still high.
    You could be right, it may just be the drive, but it would be very unusual for that to be a separate part. Car dealers generally just replace sub-assemblies these days, they don't take things apart and fix them. If you care to dissect yours, you might be able to swap out the drive and get it working again. If you go that route, you can find a little but of info here:
    Embedded.com - Inside the Toyota Prius: Part 6 - Navigation unit bridges automotive, CE
    Good luck!
    Rob
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Before you go out and spend some bucks for a new drive, pull the existing unit out and take a look at the pick up lens. Its more than likely filthy! I have seen this problem many times in CD & DVD drives. A "Q" tip, some canned air, and you may get your drive to read again. It is an optical device, and one of the dirtiest places you could stick one would be a car!!! They are not airtight and/or dust proof! If indeed the drive is shot, just buy a new drive.
    Good Luck de Pat KK6PD
  6. Razorhog
    NE Arkansas
    I've dug up some posts from similar problems, and I believe the dvd reader inside the unit is proprietary. I doubt I would be able to replace it with a standard drive, but it is worth a shot. The part # they gave me was 86841-47040. I'm not sure how much of that cost is labor, but it is not much - the service adviser told me it was a 1.5 hour job - that's only $127.50. The Toyota customer rep said that is what the units cost from the manufacturer.
  7. miscrms
    2,076
    523
    Phoenix, AZ
  8. Razorhog
    NE Arkansas
    Great replies, thank you all very much. I'm not sure what I'm going to do at this point. Will keep you updated.
  9. Razorhog
    NE Arkansas
    Just got a call from my dealership. They, along with Toyota have come to the conclusion that they cannot get a remanufactured unit, and the price is the same. The Toyota rep is supposed to contact them tomorrow.
  10. mlibanio
    mlibanio Member
    304
    61
    Toronto
    2002 Prius
    I
    Have you tried to reset it through the Display. I got that once. I bought a CD cleaner, cleaned out the unit 2-3 times. Then I removed the top off, blew it out with compressed air. Put the top part of DVD unit back on. Then I did a master reset by going into the diagnostic menu. Press the Navigation menu, then in that main menu, press the Top Left side of screen, then Bottom Left, Top Left, Bottom left then bottom right. This will cause your screen to go blank and completely reset your nav systema and clear out any errors. It worked with my generation 3 unit too!
  11. mlibanio
    mlibanio Member
    304
    61
    Toronto
    2002 Prius
    I
    Also I forgot to mention it will say "LOADING DO NOT POWER OFF VEHICLE" Wait until the screen either goes back to black again, or most times it will simply reset and go back to the I AGREE SCREEN. DO NOT REPLACE YET, as Toyota technicians are totally inept with regards to the Navigation system. I was told I had to replace mine at $4900 bucks + labour + taxes!!! All I did was those 3 simple things and it works flawlessly. If you like, PM me, and we can go over in more detail. Please keep me posted.
  12. mlibanio
    mlibanio Member
    304
    61
    Toronto
    2002 Prius
    I
    Oh and as a last resort, you can always take it to a Lexus dealership. They will service it too, as they did on my Gen 3 unit. Your unit is a generation 4 unit, by the part number, and is used in the Lexus RX350, RX400h, GS350/400, LX470, LS430 (2004-2006)... well you get the idea. And given that Lexus has vehicles more frequently equipped with OEM Navigation, they will be in a better position to help. As an example I was told by 5 Toyota dealerships that navigation systems were not available in a 2002 Prius. When I took the tech's outside, each did a double take! And of course they claimed it was aftermarket, even though the MAP, DEST, INFO button are built into the dash. Erin Park Lexus technicians, one in particular named Shafiq, told me to clean it out, and the procedure for resetting it. He neither charged me, and it worked perfectly!
  13. Razorhog
    NE Arkansas
    Awesome info!!! I am going to try this ASAP! Will let you know.
  14. Razorhog
    NE Arkansas
    I got a DVD cleaner disk and ran it, although it doesn't sound like the drive is spinning up at all. I was going to try the master reset you talked about but I don't know how to get to the diagnostic menu. It won't let me access any of the Navigation screens due to the error.
  15. mlibanio
    mlibanio Member
    304
    61
    Toronto
    2002 Prius
    I
    You don't need to. Just do this and try:
    2004-2009 Prius: Menu, Volume, top left, bottom left, top left, bottom left
    Press Navigation
    Then follow procedures as indicated.
    Does the message change when you put in a CD or is it the same?
  16. mlibanio
    mlibanio Member
    304
    61
    Toronto
    2002 Prius
    I
    It should change and say disc unreadable, replace disk. or something like that. But lets try all options before you remotely entertain replacing it! If you were really brave, you could open the unit, find the momentary black switch inside, and that clears the firmware and everything inside memory as well. That way you could be ultimately sure. There are websites dedicated to doing it.
  17. Razorhog
    NE Arkansas
    I don't understand those instructions. The menu button doesn't do anything (screen continues to say "unable to read data.." There is no volume button, nor is there a navigation button. :confused:
  18. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    did you by chance dig around in the hidden menus? if so, there is a reset that worked on the earlier 2g prius.
  19. Razorhog
    NE Arkansas
    What hidden menus?
  20. galaxee
    9,810
    465
    MD
    ok, i guess that rules out that option.
