Navigation won't load...stuck on loading map and spinning disc icon
Discussion in 'Gen 3 Prius Audio and Electronics' started by Jason Liu, Oct 14, 2014.
  1. Jason Liu
    Jason Liu New Member
    San Jose, California
    I have a 2012 Prius and when i press "Map" it won't open. It is stuck on loading page and spinning icon. Help.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Have you tried ejecting the disk and reloading? If so and under 36k miles, take it to the dealer.
  3. Jason Liu
    I don't think there's a cd for 2012 version. Also, I've passed the warranty mileage...I'm at 60K.
  4. Jason Liu
    anybody having the same issue?
  5. JC91006
    16,482
    8,400
    reset the car and see what happens.
    disconnect the 12v negative for a few seconds.
  6. Jason Liu
    when you said reset the car..do you mean turn off the car? How do you disconnect the 12V negative? Thanks.
  7. JC91006
    16,482
    8,400
    I mean to disconnect the 12v battery in the hatch area. Just the negative will work, disconnect it for 30 seconds and reconnect. You will need a 10mm socket or wrench.
    This will reboot the radio, in case it's stuck on a screen it shouldn't be stuck on.
  8. Zephyr7
    Zephyr7 Member
    301
    28
    disconnecting it wouldn't help if I am not wrong.
    U may have to get a new unit, I suspect the storage on the HW is corrupted.
  9. Jason Liu
    disconnecting didn't work.
  10. hornetmo
    hornetmo Junior Member
    Missouri
    My 3013 Prius started doing the same, "Loading Map" msg with spinning icon. Dealer wants $139 to diagnose. Sure would like to get this fixed but $$$?
  11. bisco
    49,507
    by a garmin.
  12. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    Have you tried ejecting the DVD (slot below the CD slot behind the MFD), wiping it off and re-inserting? I was getting periodic read errors while driving and ejected the disk and found some dust to wipe off. Worth a try.
