Navigation?
Discussion in 'Gen 5 Prius Main Forum' started by maiki, Aug 16, 2025 at 3:11 PM.
  1. maiki
    maiki Member
    166
    25
    New 2025 Prius Plugin XSE Premium. Agreed to trials of all the subscriptions, although not likely to continue with any of them past the trial. (Unless I find any very worthwhile.)
    So far I have used Google Maps on my phone for navigation, connected to the car via Android Auto.
    Yet it appears in the manuals that the car might also have its own navigation system. Any advantage to using it, instead of Google Maps-Android Auto? If so, how? Thank you,
    51,321
    actually, it would be a disadvantage. google is far superior to anything toyota and partners have ever produced. especially in updates.
    maiki likes this.
  3. hill
    8,686
    One of the most disgusting things about Factory Map ($mall fee$) upgrades is that too often, the new communities will still not be there. We find that so in a plug-in pacifica. Looks like we're driving across somebody's Ranch but that ranch ended over 10 years ago as now it's a town bypass.
    #3 hill, Aug 16, 2025 at 3:31 PM
    maiki likes this.
  4. PriusCamper
    PriusCamper Senior Member
    12,187
    4,950
    Pacific Northwest, USA
    Zero advantage to using Toyota's half-baked navigation software that has zero ability to update and re-route if a road gets closed or overly-congested... You'll be stuck in traffic with all the other sheep that don't know how to use real time navigation on their phone.
    maiki likes this.
  5. maiki
    maiki Member
    166
    25
    Thanks for the feedback. I guess I'll continue with Google Maps. On the Tesla I used its built-in navigation (don't know who made it), as it worked pretty well, did not require a subscription, and that car did not have Android Auto. But it looks like built-in navigation is not a good option for Toyota,
    PriusCamper likes this.
  6. hill
    8,686
    iirc - tesla maps are an integration of map box, crowd sourced maps & Google.
  7. Hammersmith
    Hammersmith Senior Member
    2,105
    2,094
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    FYI, Toyota gets their traffic data from Google.
    SM-S901U ?
  8. PriusCamper
    12,187
    4,950
    I would bet that Tesla does too... Specifically in 2013 the Google monopoly aquired the Waze app for $1.3 Billion and waze was/is a community-built crowd sourcing app to get real time info about traffic, road hazards and accidents. Even apple uses this resource in their maps.
  9. Hammersmith
    2,105
    2,094
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Google AI says yes. They both use Google Maps data but put their own interface over it.
    Personally, I use Google Maps and Android Auto, but that's mostly because I also use AA to stream YouTube videos on long trips where I need nav.
    SM-S901U ?
  10. PriusCamper
    12,187
    4,950
    If we still enforced monopoly laws Waze would still be a huge independent company worth tens of billions and they probably would of gotten into hardware and there would be way more robust competition than Google owning/controlling the Waze service that modern world navigation depends on.
  11. Paul Gregory
    Paul Gregory Senior Member
    1,730
    432
    Alberta
    2024 Prius Prime
    XSE
    There is built-in navigation, and it is much improved over the one in my Gen 3, which was terrible. This one seems to be very useable and seems to have updated information. It's advantageous when your phone is not available, or you have location services turned off on your phone. I don't use it very often, but when I have, I found it a perfectly good substitute for Google Maps.
  12. otatrant
    otatrant Active Member
    216
    141
    San Francisco
    2023 Prius Prime
    XSE Premium
    One advantage is by inputting a destination into the Toyota navigation it taps into Predictive Efficient Drive allowing you to use more of your charge without the use of gas. From my experience I went from about 150 mpg so that means like 1500 miles between fill ups to averaging more like 200 mpg so about 2000 miles between gas station visits. I think I will be able to get this higher in the future (ie more like 250-300 mpg) but took a hit recently some longer drives in between charges requiring gas.
  13. KMO
    KMO Senior Member
    1,843
    612
    Finland
    2023 Prius Prime
    Um, is that a source of unbiased accurate information about Google!?
    Here in Europe at least, Toyota are still using HERE map data, acknowledged in the version screen - lots of details about it are quite familiar from my G2, which used the same source. (Formerly Nokia maps, Navteq).
    I'd be a bit surprised if they were using different mapping data in the US, but I guess it's possible. Are there any copyright/acknowledgment messages in the system?
    Being a different system from the "native" one could conceivably explain the lack of any offline support, the markedly reduced navigation options and the lack of Predictive EV Drive. (Even if there's no fundamental technical limitation, re-implementing features for a different map API would be extra work).
    LRO likes this.
  14. KMO
    KMO Senior Member
    1,843
    612
    Finland
    2023 Prius Prime
    As I've said before (here and here), all the information I have says that the subfunction of "Predictive Efficient Drive" you're describing that needs destination set ("Predictive EV Drive") is not present in US cars.
    The function you do have ("Predictive Deceleration Support") does not need the destination set - it just uses the car's navigation in the background all the time.
    I think you'll find your change is mainly down to temperature and time of year.
    Both functions can be seen operating in my European car:
    • Predictive EV Drive switches visibly between HV Mode and Auto EV/HV on the display, as if you were pressing the drive mode controls yourself. (Switching between "try to hold charge" and "try to use charge"). And it displays messages about increased EV range at the end of the route - although it's very unclear what exactly it's saying/measuring.
    • Predictive Deceleration Support puts little leaf icons on the map at common deceleration points, and highlights them as you coast up, when it's increasing the coast deceleration. (The difference is also quite physically perceptible, although not as strong as the proactive drive assist slowdown for a car in front, and you can also see the regen clearly higher on the HSD display when it's doing it.)
    As far as I know, you should be seeing only the second of those in the US, and there's no other invisible function in the PHEV included under the "Predictive Efficient Drive" banner.
    If you do see automatic mode switching, then that would be very interesting. I'm pretty certain they couldn't avoid that being visible - the control is like a "high level" function that changes the "mid level" drive system behaviour, just as if using the drive switches, not a complex subtle integration.
  15. LRO
    LRO New Member
    26
    22
    United States
    2024 Prius Prime
    XSE Premium
    Indeed, here in the USA the Toyota embedded navigation map is "©Here All Rights Reserved" (as shown in "About" option when viewing the embedded navigation map). Toyota press releases have stated that Points-of-Interest (POI) search capabilities is provided by Google.
  16. KMO
    KMO Senior Member
    1,843
    612
    Finland
    2023 Prius Prime
    Ah, thanks. I think they might also be using Google in Europe for online POI searches too - stuff in the manual does suggest a significantly different and extended system when online.
    (But I've never actually used the navigation online, having not signed up or agreed to anything, so I can't report on the differences).
