NC/SC/Tenn 2016-2018 spare tire part exchange
Discussion in 'Gen 4 Prius Main Forum' started by yaelmobethere, Jul 29, 2020.
  1. yaelmobethere
    yaelmobethere New Member
    Asheville, NC
    Anyone within driving distance from Asheville (NC, SC, Tenn, etc.) with a 2016-2018 Two or Three interested in exchanging their spare tire and cargo floorboard setup with my 2016 Four?
    If unfamiliar, the 2 Eco, Four, Five, and Touring models replace the spare with a self-inflating tire sealant kit. Benefits include less weight and a several extra inches in the cargo area.
    I'm trying to build up the cargo floor for camping.
    Thanks in advance!
  2. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    Welcome to PriusChat. You're not alone, seeking a donut spare to replace the standard sealant kit.
    There should be several threads on this, although I couldn't find them at the moment. I made several phone calls to salvage yards (they DON'T stock the foam bits...crazy, cause they're ridiculously expensive!) scored the appropriate foam floor from a salvage yard 200 miles away, sourced a spare tire elsewhere. Be careful, IIRC, certain model years changed the shape of the foam pieces.
    Others will post, for sure. We're a friendly bunch!
    yaelmobethere likes this.
  3. Prodigyplace
    12,596
    11,792
    Central Virginia
    I have a 2017 Two and there is no way I would give up my spare tire! That is part of the reason I bought the Two. The Three was too much more expensive fir the slight benefits.
  4. pianewman
    264
    183
    2018 Prius
    You can find local used parts at car-part.com. I had to make several phone calls to various salvage yards until I found one that actually kept the foam parts from a crashed vehicle.
    Crazy. You can buy them new, but it's over $400!!!
  5. yaelmobethere
    Asheville, NC
    Thanks, all.
    Yep, I've been calling around and reaching out on several used parts search platforms, but no luck so far. Hence the Hail Mary here.
    The search continues.
  6. pianewman
    264
    183
    2018 Prius
    I just remembered an important point about searching on car-part. Since they don't list "trunk" parts, I searched for "trunk hatch", thinking that if they have a vehicle with an intact trunk hatch, the floor foam parts are probably intact. I then phoned those closest to me, found what I wanted in Houston.
    ...just a thought...
  7. yaelmobethere
    Asheville, NC
    Good idea, thanks.
