Nearing 100k miles - what scheduled maintenance need to be done?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by boochi101, Apr 30, 2014.
  1. boochi101
    boochi101 Junior Member
    27
    South Florida
    Hello all
    My 2010 prius III is nearing 100k miles. Any idea what scheduled maintenance needed at 100k miles?
    So far the only maintenance is oil changes ( i do it myself, every 7500 miles, toyota 0w20), air filters and transmission oil change at about 60k miles.
    Everything else is original including 12v battery. No after market mods. Just recently thinking of HID kits.
    Thanks!
    iPad ?
  2. JC91006
    16,481
    8,397
    coolant flush, possibly bleeding brakes, clean maf sensor and throttle body. spark plugs at 120k
  3. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Engine and inverter coolants at 100k, spark plugs at 150k.
    I would recommend a brake fluid flush, but only by someone who understands and has access to the Toyota Techstream scan tool.
    frodoz737 likes this.
  4. boochi101
    27
    South Florida
    Thanks for responses. I plan to take it to dealer for this major service.
    For brake pads/rotors, in there any warning noise comes up when the pads are getting thin like a scraping noise or any other warning messages? If brake pads not needed i would like to take it to dealer only around 120K miles.
    This is a daily driver car and plan to drive as long as possible but don't want to take to dealer often as in my experience they cause more damage.
    iPad ?
  5. JC91006
    16,481
    8,397
    You can visually see the thickness of the pads, if they look low, it's best you get it professionally assessed. Brake inspections are usually free
    SM-N900P ?
