Nearly wrecked my Prius on the highway
Discussion in 'Gen 2 Prius Main Forum' started by dbarry, Apr 7, 2005.
  1. dbarry
    dbarry Member
    114
    Houston Texas
    On April 1st I was driving my Mom to the casinos in Louisiana for her 81st birthday. Going along I-10, we had wind gusts of 25-30mph coming in from the NorthEast, as we drove directly East.
    The instability of my Prius was amazing! A gust would regularily kick the car over a foot to the side when we driving the speed limit (70 mph). After twice getting kicked off the main road, we had to slow it down to 55-60 to stabilize things up.
    Oddly enough, at a rest-stop I came across another Prius. It was a 2005 Salsa BC. I spoke to the driver, and he and his wife just plain pulled in and quit driving. It was so bad for them! They were going to detour to a nearby hotel, instead of continuing their drive into New Orleans to attend a wedding.
    I've filed a complaint NTSA's Office of Defects Investigation on the crosswind stability of the Prius. The complaint number is 10116443.
    I would ask everyone with a similar concern to file a complaint on their web site: NHTSA Link
    If they get enough complaints they'll actually test this out, and I don't think they will be very happy with the result. For my 2cents worth, I think Toyota needs to cough up for some better wheels/tires, and maybe a mod kit on the caster of the wheels as well. At least a warning sticker!
  2. DaveG
    DaveG Member
    806
    Vancouver, BC
    I had mine in a very, very strong crosswind while driving south from Oakland to LA last summer. It certainly required keeping both hands on the wheel and paying attention, but it's definately not hazerdous or dangerous.
    As you mentioned, in adverse driving conditions (which I'd say "high winds" falls under"), you're wise to just drop your speed slightly - the same as you'd do in any poor weather condition.
    Dave
  3. jfschultz
    jfschultz Active Member
    635
    114
    Germantown, TN
    2013 Prius Plug-in
    How wet was it?
    Add rain and that is what I encountered serveral months ago. Even though they only had 5000 miles on them, I got rid of the Integrities and bought Michelin Hydroedge.
  4. MGBGT
    MGBGT New Member
    42
    Extreme crosswind sensitivity and lack of stability of my 05 Prius is certainly of substantial concern to me. It's an obvious safety issue, but it also makes long distance driving very stressful, when driving under such conditions.
    I agree, it's a real problem of the Prius, and maybe even it's greatest weakness. I am continuing to evaluate this, and will probably first get an alignment, and then try different tires before I would consider this an issue for which I would file a complaint.
  5. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    Our Prius has been back and forth across S. Dakota on 1-90 several times...always windy...always seems to be from the side or a headwind. No issues whatsoever. We don't drive the max 75 MPH, usually around 65-70. GY Integrity Tires are 42/40. Well broken-in car (23,000 miles). One trip it rained the entire 380 mile trip. Not alot of wind that time, but very wet. No issues. Could it be some dealer adjustment/alignment? Maybe I just don't know what a 'stable' car should feel like? I'm coming from a Nissan SUV (and a CJ Jeep before that), so my idea of stable is different. Meaning, if it doesn't feel tippy, then it's good!
  6. kidtwist
    kidtwist New Member
    183
    I've yet to experience wind problems in my new Prius (1 week old), but I definitely had them in my little pickup truck. If the wind got above twenty-five or so sometimes I'd suddenly get moved over a foot or two. The solution was to slow down and/or make sure there were no vehicles on either side. When I'd drive my mother's Accord, wind was never a problem.
    Maybe it just depends on what you're used to. If the Prius is no worse than my old Tacoma, it won't bother me.
  7. KCPrius
    KCPrius Member
    133
    Overland Park, KS
    I haven't experienced any "white knuckle" experiences, despite driving in some VERY windy conditions. Yes, I can feel it get moved a bit, but I also could feel my Chrysler 300M blown about some on windy days. I think the effect is exaggerated by "overcorrecting" when you feel the first hit of a breeze.
  8. Orsino
    Orsino New Member
    104
    (west of) Etlanna, GA
    Let's remember that the C[sub:ecd9c0b4b5]d[/sub:ecd9c0b4b5] is measured for forward motion. In minimizing drag for the typical driving experience, Toyota can't take everything into account. Crosswinds hit a different profile on the car, and the lightness engineered into the vehicle further helps to make it easy prey.
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I can say in windy driving out here in AZ that the car can get tossed around a bit, however it's no thing that minor steering correction, reduced speed, and plain common sense can't solve.
    I also run my tires at 42/40.
  10. flying
    flying New Member
    48
    ft. myers,Fl
    I agree that the Prius is very sensitive to cross winds at any speed. However, I have been in 25-30 mph cross winds and found that by slowing down 10 mph makes the handling so much easier. I would bet that you had much higher gusts than that to move you off the road. Good luck with your complaint.
  11. heliotropehead
    heliotropehead New Member
    701
    New Orleans, Louisiana
    I drive to NOLA often (born & raised there, family& friends there, wedding will be there, etc) & get knocked around a lot! It's my only real complaint about the Prius. Perhaps I should eat more to combat the problem. :wink:
    Thanks for the link, I'll definitely add my name to the list.
  12. randalla
    randalla Member
    370
    Lexington, SC
    I'm running 40/38 in my GY Integritys and also have felt the absolute need to hold the wheel with two hands while getting blown about at 70mph.
    It reminds me of driving my Corvairs back in the Seventies. With all the weight biased in the rear of the car and the characteristically loose worm and gear steering, the handling while in windy situations could turn into a white knuckler!
  13. dvd
    dvd Junior Member
    25
    Worcester, Massachusetts
    I haven't experienced any handling problems in my Prius yet, but I've only had it for a few weeks and we haven't really had that sort of storm blow through lately.
    Could some of this "sensitivity" to wind be attributed to the tight steering on the Prius? i.e. you're feeling it more in the steering wheel because there is less play than most other cars?
    Around here, we get one or maybe two significant snow storms a year. But people drive around on their studded tires all winter. Turns our freeways into slot-racing tracks in no time flat. Get out of the "channel" and things get wild.
  14. dbarry
    dbarry Member
    114
    Houston Texas
    I'll try the higher tire pressures... is there any possibility the VSC is amplifying the problem??
  15. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    I doubt it. First off, VSC would IMPROVE stability, not make it worse. Second, if it was kicking in, you would hear chiming accompanied by the picture of a squiggly car on the dash.
    However, being that the power steering is electric, triggered by a torque sensor, you may feel less of the road in your hands. I've often suggested that the PS could be made much less sensitive at speeds greater than 30MPH.
  16. dbarry
    dbarry Member
    114
    Houston Texas
    Dan,
    That's what I thought.. and you're right about the PS being made less sensitive - it's too easy to overcorrect at higher speeds!
  17. Erick
    Erick Member
    125
    Los Angeles
    I have to agree that this was my biggest disappointment with the car, so far. We drove it out from Houston to Los Angeles and once we left El Centro, CA to drive to San Diego, this poor car got tossed around pretty bad. So bad, my wife pulled over and made me drive. It got really bad when we were going through the mountains outside San Diego and to make matters worse, it started to rain! I guess it wasn't catastrophic, I just drove around 65 and paid very close attention and tried not to oversteer at all. We just realized that we won't be taking this car on any long dirivng trips through possibley windy areas....
  18. flyingprius
    flyingprius New Member
    152
    Daytona Beach, FL
    Unless there is a significant problem with your Prius, I think this comes down to what we are used to driving. I admit the highway handling in the Prius in windy conditions is marginal, but so are many other vehicles. My mom's old 93 4Runner was awful in crosswinds and downright dangerous to drive; we worried about rollovers during windy highway driving. The Prius is far better and I don't worry about rollovers or loss of control, but I admit I must hold the wheel with two hands... but is this a bad thing? Many of us probably drive with our knees and one hand occasionally, but I think just because we need two hands doesn't constitute a problem. When I drive my mom's Audi A4 with the sport package (17 in wheels) on the highway in the wind, it's as if there is no wind at all; that's the luxury in it. In comparison to the Audi, the Toyota is annoying, but I don't think it's a safety issue.
    For reference, my windy drives were in New Mexico on the highway, my speeds were between 75-85 mph, tires inflated to 42/40, dry pavement, and 10000 miles on the tires.
  19. bethmaup
    bethmaup New Member
    57
    Austin, TX
    On our trip from Austin to Big Bend, we were buffeted about by some very strong winds--it was almost impossible to put up the tent when we got there. However, I found it similar to driving my Grand Voyager in a super-windy conditions, and my husband said that his Tacoma with camper would have been affected at least as much as the Prius. Neither of us found it a terrible strain to drive in that wind, but of course this was West Texas with NO traffic to speak of.
    On the second day at Big Bend it was relatively calm. With the 45 MPH speed limit and calm conditions, I almost felt as if I were just sitting there watching scenery go by when we were driving on the straight stretches.
    That was even true at higher speeds from Presidio to Fort Stockton on the way home, but after Fort Stockton we ran into more high winds and even a thunderstorm near Junction. Hubby had no complaints about handling when he drove, and I'm happy.
  20. KTPhil
    KTPhil Active Member
    1,379
    Check all alignment specs, especially toe-in. If it's toe'd out (allowed by the spec), it will be unstable on bumps and crosswinds. A slight toe-in is required.
    Other than that, you just have to slow down. It's a light, tall, square-topped car, all of which hurt in crosswinds.
