Need 2004 DTC De-Code
Discussion in 'Gen 2 Prius Technical Discussion' started by ononeathome, Dec 13, 2010.
  1. ononeathome
    ononeathome Junior Member
    I have search both the forums here and also Google to no avail to determine what the codes mean. I have the AutoEnginuity Code Scanner with the Toyota Enhancement pack, these are the codes that are currently showing up:
    b1c6c
    b1e6a
    b246c
    b24e4
    b2a6e
    b2afa
    p3c04
    p3c0c
    Any help would be appreciated.
    Sincerely,
  2. drew_flux
    drew_flux Junior Member
    73
    22
    sydney australia
    those codes do not look like any obdII/toyota dtc's i have ever seen. can you try and pull codes in generic obdII mode with your scaner? this may give better results. will have a double check in the manual tomorrow for you.
  3. jdenenberg
    jdenenberg EE Professor
    3,851
    1,844
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You should ask in either Yahoo's "Prius_Technical..." or at MyHybridCar where you can find Bob Wilson and his long AutoEnginuity experience.
    JeffD
  4. drew_flux
    73
    22
    sydney australia
    these codes 100% do not come up in the manual. i still think something is wrong with your scaner
