Need a bulb adapter...
Discussion in 'Environmental Discussion' started by Celtic Blue, May 3, 2009.
  1. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Okay, with the return of comfortable weather, the garage door is open a lot. And every time someone goes in and out the garage doorway, the door obstruction sensor turns on the opener lights (well, it doesn't for me, but I step over the beam) and they stay on for ~5 minutes each time. During a weekend garage sale these lights went on a lot...
    So what the heck does this have to do with topic heading you ask? We'll get there in a minute. These are two of the very few remaining incandescents in my home, and 75W, or 150W total when they are on. :eek: For those who have followed this saga before, I attempted to install CFL's in them. Problem is the bulb socket is unusually deep with a taper extending past the end of the threads. Standard CFL's won't fit them, even the smaller bases on Sylvania micro-mini twist CFL's couldn't make contact. So I need another solution, hence the topic.
    What I think I need is an adapter maybe 1/4" deep that would screw into the base of the socket with a conductor in the center and ceramic insulator around so that the center base bulb contact would actually be able to contact throught to the base. (I might be able to rig something, but this carries some risk, so I would prefer a commercial product.) Anyone seen anything that would fit the bill?
    A second idea is an adapter to fit a candelabra bulb into a standard incandescent thread. I had this idea today when I noticed some candelabra based 60W equivalent Sylvania micro-mini CFL's.
    I considered using a Dremel to cut away the extra taper extension, but part of it exends into the opener housing. Hmm...might be able to grind away some of the inner surface though... :nerd:
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    We have some bulbs on this forum that you are welcome too, with or without an adapter. ;)
    Tom
  4. Celtic Blue
    2,224
    139
    Midwest
    Sort of...ordering something like that and paying shipping for something that I'm not sure will work isn't quite the solution I was hoping for. I did a search of a few stores today while working on another project, no luck finding them in a store so far except for ones that come in the package with Bright Effects candelabra base CFL's.
    The Dremel will probably see some action soon...
  5. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Another thing to keep in mind with a garage door opener is that they are under a lot of vibration while working. Eg, go up on a stepladder, place your hand on the opener housing, operate the clicker, and you'll feel the vibration
    I've found that unless I use Severe Duty light bulbs, I don't get much life out of the bulbs. I wonder how a CFL would hold up under such use?
  6. rvndave
    rvndave New Member
    34
    Ohio
    You might consider screwing in an adapter to make an outlet instead of a bulb socket. You can get a bulb outlet at most any hardware store, cut the end off an extension cord, and wire this to the bulb outlet. Mount your light where you like. This will fix the deep socket, remove the vibration, and relocate the light to a much better position than inside the door opener. I suspect on sale the material cost should be under 5 bucks, and take about 10 minutes to make, provided you have the tools. Wire cutter, something to strip the wire, and a flat blade screwdriver should cover this job.
    on edit
    You will need a couple of screws to hold the light onto the ceiling, I would get a small anchor kit while picking up the other materials. Save ya some fuel for that 2nd run to the hardware store. Add a few more bucks to the project.
  7. Celtic Blue
    2,224
    139
    Midwest
    I've heard some folks say that they were losing incandescents in garage door openers and other applications because of the vibration, and that is why they went to CFL's...so I'm not sure which is going to be more prone to vibration related failure.
    I did replace the incandescents in the smaller opener (Prius' bay) a few months ago. Those CFL's are still doing fine, but until they've lasted 5 years or so it would be hard to draw a conclusion that they aren't sensitive to vibration induced failure.
    rvndave,
    The outlet adapter is not a bad idea. I figured out how to remove the actual socket earlier today. It clips in and has plug in pins. I'll have to check as I might have room to mount new sockets within the lenses, parallel rather than sticking out of the body at ~30 degree angle as they do presently. I'll probably have to make a cover for the resulting hole in the housing though, else the internals could turn into an expensive bug zapper.
    This is a belt drive LiftMaster 1280 1/2 hp, but the current 3280's appear to be almost identical from perusing the manual (different lens allows 100W vs. 75W in my older one.) Interestingly the newer manual says not to use "short neck or specialty light bulbs" and not to use halogens. No mention is made of CFL's although they do say "incandescent only" which leaves one wondering Wth? This is especially true as they warn of the possibility of overheating...ain't gonna happen with a CFL, but has already happened with the incandescents in the existing housing. The surface is melted in several places--I suppose the previous owner put in some 100's rather than the 75's that are in there now?
    LiftMaster really needs to update this design. The constant ~6W draw should be reduced to sub 1W, and the light sockets should be made CFL compatible. Doing these two things would reduce power consumption by around 75% (about 60 kwh/year in my case.) Ironically, the motor operation is around the same as that of the energy consumption of the lighting, and both are swamped by the vampire load of the device. There would be some cost from redesign and retooling, but actual production costs should be essentially the same.
  8. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    You can get a light sensing socket for maybe 5 bucks that will thread into a regular socket. It is small enough it might fit into the space you have. Not sure it will work with a CFL, but if you tape over the sensor, it should think it is "dark" and deliver the full current to the bulb.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    The light fitting in my garage door opener has a screw on collar. If I couldn't get a CFL in the socket I'd measure how much too long the collar was and remove it and cut it to length. I'm not recommending messing with a light socket but it is what I would do.
    I have had a CFL in each of my garage door openers for years, I got sick of replacing incandescent globes due to vibration. The CFLs have lasted really well.
  10. jayman
    13,439
    640
    Winnipeg Manitoba
    Oh boy, isn't that the truth? For a new redesign, why not just go to LED lighting, which should last the life of the opener?
  11. hill
    8,153
    Ours are two years old as still ticking.
  12. Celtic Blue
    2,224
    139
    Midwest
    It certainly would be a good option, perhaps with a price premium since it would actually cost substantially more for the same light output. The advantage of CFL capable is their unit production cost would be lower so I suspect having both light package options would be smartest for them. The LED could even be a direct plug in socket/lens replacement kit for existing or new openers. Cha ching! :wof:
    You have to wonder why manufacturers sit on their duffs and don't recognize such promising niche markets--especially ones that are likely to become dominant rather than niche in the coming decade. This wouldn't be a hard sell to customers.
    The difference in power consumption between a CFL and LED for this should be negligible. The physical durability of LED lighting would be nice, and it should be insensitive to heat/cold as well.
    Meanwhile, I'll keep my fingers crossed that the CFL's last the lifetime of the opener--they should if vibration or the elements don't take them out. I'm certainly not expecting them to last that long...one of the reasons I'm working on an adaptation for $1.50/bulb CFL's, rather than the $4.50/bulb specialty CFL's.
  13. jayman
    13,439
    640
    Winnipeg Manitoba
    Huh. With regular bulbs, I never got more than 2-3 months out of them before they burned out. With "rough service" bulbs - the kind used for trouble lights and whatnot - +5 years
  14. jayman
    13,439
    640
    Winnipeg Manitoba
    That would be the catch in most of Canada. I have an insulated, heated attached garage, but 95% of my neighbors have an attached garage with bare studs and open trusses.
    I'm sure there are CFL's rated for use below 0 F, but I haven't come across them yet
  15. Celtic Blue
    2,224
    139
    Midwest
    Below 0 F would be tough, but Sylvania's micro-mini CFL's packaging says the reliable operating range starts at 0 F. Haven't tried them in cold weather so I don't know how they actually perform (mine are inside.)
    Cold weather is hell on standard interior incandescents too in my experience. I noticed what appeared to be a strong correlation between increasingly cold temperature and failure of the incandescent filaments (back when I was still in high school/college and experiencing some nasty midwestern winters.)
  16. jayman
    13,439
    640
    Winnipeg Manitoba
    Never noticed any unusual issues with regular lightbulbs in extreme cold. One of my neighbors replaced the PAR soffit mounted floodlights in his home with CFL's last summer. Naturally, they worked well in summer. Once the temps got down to +15 F, they took forever to light up and flickered, and by 0 F, they were dead
    I wonder how well PAR replacements in LED work?
    High-Power Frosted-Lens Soft White PAR38-Style LED Light Bulb Replaces Incandescent PAR38 Lamps
    Too bad they're so expensive. But I've noticed a lot of folks in my 'hood run their PAR's all night. Since they don't have a light sensor circuit - should be mandatory IMHO - most of them are on 24x7. They're out there 2-3 times a year replacing PAR's
  17. Celtic Blue
    2,224
    139
    Midwest
    It is done. :thumb: Didn't even have to get out the Dremel, just a pocket knife, hacksaw, and some needlenose pliers. I wasn't satisfied with the selection of socket replacements and the amount of fabbing I would have to do, so I decided it was time for a bit of reconstructive surgery to the existing sockets.
    I cut the interfering outer extension cone away from a little over half of the existing socket using a hacksaw. Then I used a pocketknife to carve down as much material on the other side as I could without destroying the structural integrity of the clip-in portion of the socket. This was enough to get the micro-mini's to work, but the regular n:visions CFL bases were still not quite making contact with the bottom. So I bent the bottom contact upward a mm or two with the pliers. Now the n:visions fit too, and for 1/3 the cost of the micro-minis.
  18. jayman
    13,439
    640
    Winnipeg Manitoba
    Good to hear the job is done.
    Of course, you had the opener unplugged while doing all that work .... right?
  19. Celtic Blue
    2,224
    139
    Midwest
    Better still, I was able to unplug and unclip the sockets to work on them at the bench. That's what made the process so much simpler. It took a few iterations of testing to get it worked out on both sides with minimal material removal.
  20. jayman
    13,439
    640
    Winnipeg Manitoba
    Gotcha, no risk of getting a shock and falling off a stepladder
