Need a Key FOB for 2001-2003 Prius
Discussion in 'Generation 1 Prius Discussion' started by adric22, Jan 12, 2010.
  1. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    Unfortunately the Prius I bought only came with a single key and no FOB at all. However, I have determined it does have keyless entry I just need the FOB. I was quoted a ridiculous amount by a toyota dealer. And I'm also told that not just any old Toyota remote will work. So I either need a remote that came with a 2001-2003 Prius or I need somebody to read me the FCC-ID number on the back of their remote so that I can confirm any used one I get will be compatible.
    So.. anyone reading this, can you tell me the FCC-ID on your remote? (all the numbers should be the same, so there is no way I can use that number against you to open your car, etc..)
    Or if anyone has one they care to sell me..
  2. tochatihu
    tochatihu Senior Member
    9,046
    3,528
    Kunming Yunnan China
    2001 Prius
    2002 TOYOTA PRIUS Keys and keyless entry remotes
    I have forgotten the programming instructions. I think that since you have a functioning transponder key you can make it work. I'd also suggest the purchase of a spare key, and cut and program that.
  3. adric22
    642
    144
    Fort Worth, TX
    hey thanks for the link, those prices look way better than the prices quoted at the dealer, even just for the merchandise itself. I know how to program the FOB, but the key itself I might have to get the dealer to do that.
  4. bwilson4web
    15,513
    The car 'learns' the FOB and the key but from what I remember, you need a working key to teach a new key and a working FOB to teach a new FOB. I could be wrong but that is what I remember.
    The bad news is if the key and FOB are lost, the NHW11, 2001-03 Prius, required an expensive ECU to be bought with a master key and fob.
    Check the archives here and over at "Prius Technical Stuff."
  5. adric22
    642
    144
    Fort Worth, TX
    Oh the IRONY. A friend of mine found a FOB and gave it to me yesterday. I programmed it and it does actually work. The problem is the actuator on the driver's side door appears dead. The other 3 doors work fine.
    Shouldn't be a problem as I have the original key.
  6. tochatihu
    9,046
    3,528
    2001 Prius
    Good for you adric, but I still suggest getting (and programming) a spare key unless you are the type of person who doesn't lose things :)
  7. adric22
    642
    144
    Fort Worth, TX
    Oh definitely. I'm going to get a copy. I have already inquired at several places. I'm just trying to find the best deal.
  8. bbcb
    bbcb Junior Member
    Houston
    If you buy a key off the Internet, make sure you have already lined up a locksmith that will cut it - otherwise, you'll have to buy one from them and beg them to cut your other key as well.
    I could find no one in my area that would cut a key brought in. They all wanted the key sale.
  9. cthindi
    cthindi Member
    177
    85
    Connecticut
    As far as physical key is concerned any Home depot store would be able to copy it for you for about 2 or 3 dollars. Since you do have a working key that should not be a problem.
  10. bwilson4web
    15,513
    I bought my spare key from the dealer but the spare fob was bought on the Internet. I could have saved a little buying the RFID, blank key from Ebay and that is what I would do if I lose my backup key and fob.
