Need Advice-Considering 2011 Prius, "Monitor Not Ready" CAT/EVAP/O2
Discussion in 'Gen 3 Prius Main Forum' started by PriusResearcher, Mar 27, 2019.
  1. PriusResearcher
    PriusResearcher Junior Member
    Hey Everyone,
    Thanks in advance for the advice.
    Considering this Prius for sale. 2011 Prius with solar roof. 170K miles. Asking Price $6,500.
    Just got back from Pre Purchase Inspection from my mechanic.
    Everything is good except, there is some missing information that the mechanic could not figure out. This issue is holding up the sale, and I'm wondering if there is some shady stuff going on from previous owner.
    The issue:
    On diagnostics, mechanic says that the Monitors for CAT,EVAP,O2,and Heated O2 are all "NOT READY" for the current cycle.
    The last time that the DTC was done, all of these issues were "COMPLETE", however, now on this cycle it is NOT READY.
    This doesn't make sense since the seller has been driving it regularly for over two months. He's only just bought it, but says he is moving.
    Another perhaps unrelated issue:
    There is an open recall for a software update not yet applied to this car. NHTSA #18V684
    Seller also says he took it to mechanic to get EGR all cleaned out, new spark plugs, and new brake pads. But he did not keep any records for that service.
    Otherwise it has had regular service.
    So, this is it. Mechanic says that a new CAT might cost in the range of $1K-$2K to fix. Wasn't sure about that number.
    So, wonder does anyone have any advice or other places I might look to understand what this is?
    Is this a decent price for this car? Other than this, the car is in great shape otherwise.
    Is this a good year/to get?
    Thanks everyone. Any insight would be appreciated.
  2. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Was the engine hot enough to get good readings? Could it be that trouble codes were cleared recently and the car needs to be driven a few more miles before it is ready to report those numbers?
    Gearbreaker and PriusResearcher like this.
  3. ChapmanF
    17,943
    After a code clear, the emission-test monitors will show "not ready" for a certain number of driving miles, before current results will be shown again. It works that way to thwart attempts to pass emission inspections by clearing trouble codes just before going in for inspection.
    If they showed COMPLETE at some recent time, and now they show NOT READY, there has been a code-clear done since that earlier time. If buying the car, it's in your interest to inquire why, and what the codes were that were cleared.
  4. PriusResearcher
    Hm. That sounds right.
    The rest of the codes came back fine except the ones related to the catalytic converter and sensors.
    So I am actually wondering if the seller is clearing the codes because of a problem with the cat and trying to sell me a car with a bad cat.
    I'm thinking back to my interactions so far and there are some "yellow flags" in our conversation. He didn't seem too surprised about this issue, but got upset that the deal wasn't going to work and just left.
    Thanks for the insight everyone who read this.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Mileage is high and these cars are prone to head gasket issues at high mileage. I wonder if the seller did this work to try and solve a misfire code prior to selling the car. If you reset a check engine light, it can sometimes take 50-100 miles for all monitors to run and pass.
  6. Leadfoot J. McCoalroller
    8,048
    7,528
    Pennsylvania
    2018 Prius c
    Given how valuable it it would be to have proof of that good stewardship, you'd think he'd at least try to get a duplicate of the receipt from the shop that did it. Hmm.
    Yep, about right. Bail out, research another one.
    kc5dlo and PriusResearcher like this.
  7. PriusResearcher
    Yeah, I think I'm out on this one.
    The more I run through my interactions, the more I'm questioning the sellers actions.
    Thank you everyone for the help in getting me to this decision.
    I'll just have to keep looking.
    If anyone has any advice on a year or model Prius I could get, or should look for in particular, at this price range $6500...I'm all ears. Must have sunroof. :)
  8. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Monitors scans the car while driving for any critical problems with certain systems such as EVAP, which then trips the CEL when something wrong detected. When you unplug the 12v battery from the vehicle system or use a OBD2 reader to turn off/erase the CEL code(s), CEL goes away, and all monitors goes to an offline state. When plug 12v bat onto system & start car, each monitor has their own interval when to run/scan test the car. Some mechanics have told me monitors may take up to 50 miles of HWY driving to come back on-line and begin scanning again but in my opinion it changes from manufacture to manufacture.
    In CA, smog check doesn't require all monitors to be on-line to pass smog check. One time I had 4 offline and still passed but it wasn't the critical monitors they said.
    Since it's the EVAP monitor, don't walk away from it. RUN.
    #8 Grit, Mar 28, 2019
    PriusResearcher likes this.
  9. Leadfoot J. McCoalroller
    8,048
    7,528
    Pennsylvania
    2018 Prius c
    From my point of view, this one had three screaming red flags (the guy taking off was #3) plus the unspecified yellow flags you mentioned. And you were still thinking about it. Think about that. I think you need to work on dismissing unfit candidates earlier in your checkout process.
    kc5dlo likes this.
  10. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    The Prius is a popular car with many on the road. A good candidate for purchase should not be too difficult to find.
  11. ChapmanF
    17,943
    Only mine is still popular with me, so you can't have it.
    kc5dlo likes this.
  12. Gearbreaker
    Gearbreaker Junior Member
    29
    Vernon, CT USA
    2014 Prius v wagon
    Sounds fishy to me too.... There are more fish in the sea. If it walks like a duck, quacks like a duck and looks like a duck, it's a rat :)
  13. ChapmanF
    17,943
    Anything that walked, quacked, and looked like a duck in 2019 may well sound like a fish and smell like a rat in 2023.
  14. Gearbreaker
    29
    Vernon, CT USA
    2014 Prius v wagon
    Lol :)
