Need advice - Generator Control Module / DC/DC Converter
Discussion in 'Gen 3 Prius Technical Discussion' started by RachelsCreeds, Oct 23, 2024.
  1. RachelsCreeds
    RachelsCreeds New Member
    Virginia
    2013 Prius with almost 190k miles. A few weeks ago, the car kicked hard while I was driving 5mph, then every light on the dash came on, including the “Check Hybrid System” light.
    Got a code reader and got the following codes:
    P0A94 - DC / DC Converter
    P0A1A - Generator control module
    C1310 - Speed wheel RF comparison failure
    C1241 - Low battery positive voltage
    C1310 - Unknown issue/Abs
    The repair estimate the code reader gave was astronomical, and my family member said they think they may be able to repair it if I can buy the correct parts.
    Has anyone seen anything like this before? And would it be worth it to try to replace the GCM before I mess with the DC converter? Any advice or guidance would be incredibly helpful right now.
  2. Brian1954
    Brian1954 Senior Member
    1,705
    665
    South Central PA, USA
    Your inverter problem is probably covered by a 20-year extended warranty. Do NOT clear the trouble codes. Take the car to your local Toyota dealership for diagnosis. If the inverter is covered, it will not cost you anything for the fix.
