Need advice on 12 volt battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kingtucker, Jul 27, 2015.
  1. Kingtucker
    Kingtucker New Member
    Greenville Ky.
    I have a 2014 prius. Thinking about a road trip and doing some camping. But have read some bad things about the 12 volt battery. Would like to know my best options for running a iceless cooler or blowing up a air mattress.
    Also, what is the best replacement battery I can buy.
  2. JC91006
    16,673
    8,518
    There's nothing wrong with the battery, you just have to use accessories while the car is in Ready Mode.
    Iceless cooler is great with a separate inverter running. However it's not great once you have to turn off your car. You can bring 2 coolers.....just in case you run out of ice and can't buy it.
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    those fridges aren't very good, a cooler and dry ice is good for about 4 to 5 days
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Here is the simple rule, any time you need any electricity, have your Prius in Ready.
    It will run the engine about every 20 minutes, and you will never have any 12 volt battery issues.
    Right now the best battery is from Toyota, if only because it has a 84 month (prorated) warranty
