Need advice on front wheel hub replacement
Discussion in 'Gen 2 Prius Main Forum' started by Aegean, Sep 30, 2019.
  1. Aegean
    Aegean Active Member
    454
    203
    Alexandria VA
    I have to replace my front wheel hubs on my 2006 Prius. I read in this forum that many people have really hard time separating the steel wheel hub from the aluminum spindle using penetrating lubricant, pullers, slide hammers, presses, torches etc.
    Then the quality of the OEM wheel hubs (marked Toyo) is substandard and is a common repair on the Prius. Moog, timken and Skg have even worse reviews. Should I try buying two used spindles (that include wheel hubs) and replace the whole thing quick and dirty? The used spindle/ knuckle assembly sells cheaper than the aftermarket Chinese wheel hubs. Even if they fail in a couple of years I will have my old ones pressed out in a machine shop, fit new wheel hubs and replace them again. What is your advice?
    SFO and PriusCamper like this.
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Sounds like a wise way to do it if it's your own car and you don't mind doing more work in the future... Nice thing about a bad wheel hub is that it'll let you know it's gonna fail long before it actually fails.
    Aegean and SFO like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I did the hubs on our old blue 2005. I used Timken. They seemed like a nice assembly to me.
    I borrowed a puller/slide hammer from AutoZone. It was a bit of a pain, but after reviewing the work, I think the difficulty comes into play getting the old one out due to the hub cocking, not due to any white corrosion that's present on the aluminum. The four mounting bolts for the hub are not equally spaced. This results in the hub puller not being perfectly aligned to the center axis of the hub. Of course, this results in the hub not being pulled straight out. Just something to be aware of. I was able to swap the hubs without removing the knuckle, but many procedures have you just remove the whole knuckle and press the hub out. This can require an alignment afterward. No alignment needed if you just yank out the hubs.
    Also be aware you will probably want to get two new spindle nuts ahead of time. You have to be careful when removing them, as the nut gets staked during installation to keep it from loosening. If you do not "unstake" it enough, you will damage the spindle threads when you rotate the nut. Personally, I used a Dremel tool with a cutting wheel to grind the staked area clear. The nut came off perfect with zero damage. New nuts went on perfect also.
    If this was something I did more often, I would make a custom hub puller tool to have proper alignment. I think it would make all the difference in the world for this job.
    #3 TMR-JWAP, Sep 30, 2019
  4. Aegean
    454
    203
    Alexandria VA
    Usually that is true. On the front left I keep hearing a minor noise for the past 30000 miles when I turn right and the weight goes on the left one. But this week out of blue the right wheel hub started and it is 3 times louder than the left without any warning. Strange thing! It proves that Toyota had a design error using theses hubs on a Prius.
  5. Aegean
    454
    203
    Alexandria VA
    This makes a lot of sense! I wish someone had created a heavy duty puller just for the Prius.
    PriusCamper likes this.
  6. Stimp
    Stimp Member
    53
    North Carolina
    A small sledgehammer, air chisel, and 30min are all I needed to extract the old hub. If you can get the slightest gap between the hub and knuckle it's over really fast with an air chisel. I went with the OEM Koyo hub.
    Aegean likes this.
  7. jessiejosco
    jessiejosco Member
    62
    42
    I just replaced all four wheel bearings on mine and a couple on my wife's this summer. Pretty sure, where I live, it is the corrosion that makes them really difficult to get out. The first one I did a few years ago, I wasted a couple of hours trying to leave the steering knuckle on. I ended up having to take the knuckle off anyway. I have seen a mechanic do one on my wife's car with an air chisel but it took him a long time with a lot of swearing, and he wrecked the splash guard. If you have the knuckle off the car, a sledge hammer will blast the hub out of the knuckle pretty easily. My 4 ton press would not budge it.
    If you live in an area with rust I would not recommend trying to take the ABS sensor off the knuckle. The bolt for the sensor is really soft and will snap off very easily. I learned this the hard way. Now I unplug the sensor at the other end from under the wheel skirt and take it off with the knuckle.
    Our cars are on their third set of front bearings and I have used SKF, Toyota, and Koyo. Until recently they all seemed to be sourced from Koyo and last about 130000 km before they start to howl. SKF is all over the place now. I got two this summer that were made in China and looked fake. I did check with SKF and they said they were fine. Another SKF bearing I got for the rear was made by NSK. So you really don't know what you are going to get.
  8. Mendel Leisk
    40,584
    Do you some sort of grease when installing replacement bearings, in the cavity they push into, and does that help much, with subsequent removal?
  9. jessiejosco
    jessiejosco Member
    62
    42
    Yes I use the silver anti-seize, but I am not sure if it helps because I have not replaced any of those bearings yet. When the cars were newer the dealer replaced the first 2 or 3 until I got tired of paying 600 bucks a bearing. They were not kind enough to use anti-seize.
  10. Aegean
    454
    203
    Alexandria VA
    What about the axle nut stake? Do I need a special tool? They sell some needle shaped tool but is it needed?
  11. Stimp
    Stimp Member
    53
    North Carolina
    Removal or installation? A quality impact wrench will take the nut off without fussing with the stake. On installation use a center punch or chisel to stake it.
    Aegean likes this.
  12. ChapmanF
    17,347
    :eek: After which it would be an excellent idea to also replace the axle.
  13. Mendel Leisk
    40,584
    Yeah take the time and unstake the nut. I've see dealerships (Honda) reuse the nut: nut was back on, rotated slightly further, staked in a slightly shifted location. Probably overtorqued too?
  14. Stimp
    Stimp Member
    53
    North Carolina
    I've done it, no effect on the axle. Are you just speculating?
  15. ChapmanF
    17,347
    No, I'm reading the repair manual, is all.
    That was from a Gen 3 manual, but you should be able to find the similar passage in yours.
    If the spindle threads take damage, bets are off as to how well the next nut will hold after reassembly.
    Some repair techniques can create known risks and still cause "no problem" much of the time, leading people to report having used the techniques with "no problem." But when a warning about the technique makes it into the manual, generally it has caused somebody a problem.
    Aegean and Stimp like this.
  16. Stimp
    Stimp Member
    53
    North Carolina
    Ok cool, thanks for the reference. I'd do it again, unless the stake was set unnecessarily deep. Softer metal of the nut versus hardened axle.
  17. Aegean
    454
    203
    Alexandria VA
    I found the proper procedure for unstaking the nut with some more detail.
  18. Mendel Leisk
    40,584
    In a pinch a Roberts Head screw driver looks like it'd work for the unstaking?
  19. Patrick Wong
    18,200
    6,493
    I am wondering why the procedure says not to use an impact wrench. I would expect to use an impact wrench to loosen the nut after it is unstaked.
  20. Mendel Leisk
    40,584
    Maybe they're thinking use of an impact wrench will "mask" the condition of a nut only partially unstaked?
    Just musing: castle nut and cotter pin would be another design option for the manufacturers, though not infinitely variable.
