Need Advice on Timing Cover Gasket for 2013 Prius v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by DRuss, Apr 2, 2026.
  1. DRuss
    DRuss New Member
    Nashville TN
    2013 Prius v wagon
    Hello all, I have a 2013 Prius v with 132K miles. I just found this chat forum last week, so thank you. I just took my Prius in to the dealer for a checkup which included draining and refilling the various fluids, oil change and a new set of tires. They explained that the Timing Cover Gasket needed to be fixed/replaced. The estimated cost is $3,597. I understand this is to avoid a major leak of oil over the engine. How many of you have had this problem, and should I have it done now? Thanks in advance.
  2. PriusCamper
    PriusCamper Senior Member
    13,115
    5,316
    Pacific Northwest, USA
    Toyota Stealerships are not your friend... If you aren't getting warranty work for free, it's equivalent to giving them bank account info so they can help themselves. You need to find a friend or family member or local mechanic who shares in your interest to keep repair costs low. We'd be happy to assist whoever you find.
    As for valve cover, first step is to clean it and put cardboard under your car so you can track how much the oil loss is. Usually these leaks are good for just a few drops a day and the criminals at the Stealership think that's enough to take advantage of you, when in truth this is perfectly normal for a 13 year old car.
    As for the tires... Stealerships are NOT a tire shop, they offer you no selection or reasonable pricing or free flat repair, rotation and balancing. Lastly, even the most honest tire shops will try to sell you a new set of tires before your old ones are worn out.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,586
    6,639
    Texas Hill Country
    A timing chain cover leak on these engines is common and will get oil on everything over a period of time. But it is unlikely to amount to more than 12 oz over an oil change. It is enough to spot your garage floor and make other jobs messy.
    By the book this is an engine out job so the dealer will charge it that way regardless if the tech does it in the car or not. The tech will probably do it in the car and still get book hours.
    They may be charging standalone pricing for the needed oil and coolant changes.
    Its likely they have included related parts such as a new timing chain tensioner and perhaps oil pressure switch. Always ask for detail. You don't need a chain or guides.
    Most independents would charge $1200 or less and would do it in the car. It is more difficult access but saves many hours of labor. All of the parts are reusable; you are getting new form a gasket sealant, new fluids, expertise and labor.
    #3 rjparker, Apr 2, 2026
  4. DRuss
    DRuss New Member
    Nashville TN
    2013 Prius v wagon
    I thank you for your quick response. I have used the dealership for most of the oil changes beyond the warranty, but I did purchase the first set of tires from another provider. That set was practically shredded when I took it in last week although I had them regularly rotated. However, when the Toyota Advisor was preparing the quote, I called the previous tire store and got a quote from them. The dealer quoted a price about $300 over, but then they matched the tire store quote and did the alignment and balance. So I felt it was a good buy. As for the Timing Cover Gasket, I'm going to shop around.
  5. DRuss
    DRuss New Member
    Nashville TN
    2013 Prius v wagon
    Thank you for such good advice. I'm going to shop around for an independent mechanic and get their rates. If I decide to go with the dealer, I'll ask for the detail as you suggested and use that to save some money.
  6. Mendel Leisk
    41,956
    That quoted price is way too high. Have a look for yourself, see how bad it is. It’s a form-in-place gasket (tube of sealant), has been prone to leaks. Standing at front of car, it’s at left end (passenger side) of engine. Looking down there with some light you can get some idea. Better is to raise that corner (or the whole front with a floor jack), remove right/front wheel (passenger side), pop a few fasteners off the plastic wheel well liner and flex it out of the way.
    previous response
    DRuss likes this.
