Need Battery Help
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by GetAPriusTheySaid, Jun 9, 2022.
  1. GetAPriusTheySaid
    GetAPriusTheySaid New Member
    Fort Worth, Texas
    My Car acts as if it wants to start but wont go into ready. I have a brand new 12v battery. It says I need to replace hybrid battery pack pull over immediately. What should I do?
    49,444
    confirm the new battery voltage at the jump point under the hood (does the 2013 c have this?)
    if the battery and connections are good, you will need tech stream to read the trouble codes.
    a 2013 c in texas heat, could very well need a new hybrid battery
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,963
    4,709
    Texas Hill Country
    Did you mess with the orange plug on the hv battery? If so, it may not be properly engaged.
    Doug McC likes this.
