Need grid charger
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kevin Wilson, Jan 7, 2025.
  1. Kevin Wilson
    Kevin Wilson New Member
    Carnation Washington
    So everything started with a friend helping me out with some gas. Unfortunately it had a lot of water in it. The car lost power and I was stranded on the side of the road less than 5 miles away from home at 1:00am or so. I didn't have any money to be able to call a tow truck no one had a dolly or trailer to tow it home. So in the rain and dark I got pulled home that night. I took the tank out and cleaned all the water out I also removed the injectors a cleaned the and all the fuel lines. But when I went to start the car it would barely run and the traction battery was completely dead. I'm pretty sure I need to charge the traction battery to get the car to actually start up. I'm currently out of work and my wife is having health problems that we can not get a diagnosis for so she is not able to work right now. I was just wondering if there is anyone who lives anywhere near me that has a grid charger I could possibly use? I am going to build one but I have been having a spend the little money I can manage to earn on fuel to drive my suburban to my wife's appointments. I live in Carnation Washington it's about 30 miles east of Seattle. If anyone can help me with parts to build one or has one I could use to charge my car up I would love you forever for your help. If you would like to contact me text me at 4252819618 anything is greatly appreciated.
    Thanks
    Kevin Wilson
  2. PriusCamper
    PriusCamper Senior Member
    12,010
    4,879
    Pacific Northwest, USA
    Just texted you... While most cars can start on just a gallon of gas after error code for lack of fuel, a Prius can often require several gallons to work again.
    Hopefully I can find a way to help... My life is an equivalent mess right now. But I'll do my best. And while I can't afford to drive out to you at the moment and help with charging & diagnostics (unless there's a worthy trade) I'll do all I can to help online and possibly help cover shipping costs of a grid chargre once we know your error codes.
  3. Kevin Wilson
  4. PriusCamper
    12,010
    4,879
    I suspect some of those codes are ones stored long ago... It seems you've done enough work on fuel system, but might take some extra engine cranking to fill up all the lines again. At this point you're gonna wanna look at the spark plugs to get a sense of how the combustion chambers look.
    Also do as thorough of an inspection of the engine as possible to make sure there's not anything more obvious than water in the system.
    Hopefully your lack of messaging me means you made progress on getting a grid charger?
