Need Headlight boot for wreck rebuild my nexy daily driver
Discussion in 'Gen 2 Prius Main Forum' started by specialtyneed, Aug 31, 2015.
  1. specialtyneed
    specialtyneed Junior Member
    75
    16
    Central US
    Re: Our "06 Driftwood Pearl total front end bought wrecked for $ 1200 rebuild is about 90% done:
    But we bought a DR LH headlight assy and swapped out boot & bulbs then later a Pass RH headlight assy as found fwd mount broken off that came in today w/ slight cosmetic damage via ebay but discovered the origional RH light assy rubber boot & ring for high/ low beam bulb was missing and I searched a lot to no avail.
    Anyone know where to get oem part #, IPC or find one new or aftmkt as salvage cars here are stripped of headlight assys currently?
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    So you have non HID headlights? Original part number is 81139-47060
    But probably used one from collision damaged headlight would be cheaper.
  3. specialtyneed
    75
    16
    Central US
    Yes, that is it non HID. Thank you valde3. It was a terminology problem parts catalog calls 832-282-3101 a headlamp socket cover. That site does not work good at all on mobile but this correct part name & # helps searches a bunch.
    We are grateful :)
    SM-G900T ?
  4. specialtyneed
    75
    16
    Central US
    Weird the number changed when copy & paste. But I did get correct one ordered for about $ 15 on ebay.
