Need Heat Reducing Accessories
Discussion in 'Newbie Forum' started by mothergreen, Aug 16, 2012.
  1. mothergreen
    mothergreen New Member
    1st time poster. Driving a 2007 Prius, 150,000 miles. It's a hard worker like me, but interior has too much heat buildup. A dash cover might help, but the windshield conducts the sun - it's like a furnace. Are there any of the exterior visors/canopy/awning - type things you see on the classic cars and trucks?
    Any other thoughts would be appreciated.
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Window tint will make a noticeable difference... Car cover will make an even bigger difference... Window covers for all windows (see priuschat store) will make the most difference but it takes a buncha time and effort to put them on and take them off everytime you park...
  3. alekska
    alekska Active Member
    435
    138
    Atl
    I made an EXTERNAL custom-shaped windshield reflective shade from the same material as regular ones (plastic bubble-rap kind with Aluminum film on both sides). The material in a roll can be bought at LOWES. I made the screen from pieces that were attached together with clear scotch tape.
    The first iteration design was on magnets that were attached with tape at the perimeter. It was holding very good but magnets started scratching the clear coat so now v2 is attached by blue painter's tape. Ugly but doesn't scratch the paint. EXTERNAL shade (I use it for both windshield and hatch) keeps car much cooler than internal shade. especially if you can crack the windows down a little.
    Good luck,
    - Alex
    PS: this is for the parked car of course
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
  5. richard schumacher
    7,664
    1,043
    United States
    If you can't park in a shadow (more precisely, where a shadow *will* be when you return to the car), a custom fitted Sunshade for the windshield can help a lot. Use one and park facing south or southwest.
    Even with no shade, if the Prius takes more than about 15 minutes to get comfortable then there may be a problem with the A/C.
