Need help: Battery and warranty Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Raghav, May 28, 2013.
  1. Raghav
    Raghav Junior Member
    39
    I own a 2007 Prius - i am second owner. When I purchased the car around 6 months back, the battery used to stay @7/8th capacity (7 bars out of 8 in the battery indicator on info screen) showing green most of time. From past 8-10 weeks, it is around 6/8th capacity most of the time, and drops to 5/8th and 4/8th capacity now and then. When I am driving inside city with lot of braking, it goes up 7/8th, but returns to 6/8th soon.
    Mileage is around 96k now. I live in Massachusetts. Am I still covered under warranty for battery? Can I claim warranty for this condition? Is warranty upto 100k or 150k in mass? How much will battery cost?
    Thanks in advance.
  2. jdenenberg
    jdenenberg EE Professor
    3,860
    1,859
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes.
    No, You must get a OBD2 code warning from the Battery ECU before a dealer will determine that your HV battery has failed (From your description it hasn't failed yet).
    150k, but where was your Prius first purchased? That will determine if you still have a 150k mile/15 year warranty.
    A new battery from a good dealer (there are many dealers that would charge more) is $3500 installed. You can also get a rebuilt battery installed for just over $2000, or a salvaged battery installed for about $1200
    JeffD
  3. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I do not think u have a problem with your HV battery.
    kenoarto likes this.
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Battery SHOULD be in the middle of the chart (aka 4/8ths). Something is wrong when it it is consistently 7/8 charge.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You are worrying too much. The battery is behaving normally. 6 months ago (in the winter) you probably used the heater quite a bit which kept your battery charged green. Heat = waste. Now you are probably running without heat and maybe even AC so the battery will stay in the happy zone of blue bars.
    There is nothing wrong with your car, just drive it.
    cwerdna likes this.
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    HaroldW likes this.
  7. Raghav
    39
    Thanks guys, that was reassuring :)
