Need Help: Broke 2010 Prius Rear Spoiler
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toyotatrd, Mar 26, 2011.
  1. toyotatrd
    toyotatrd Junior Member
    38
    Knoxville, TN
    Well this morning my wife was backing up and she forgot the door was already up and she hit the garage door opener again and she backed up and has pretty much mangled the rear spoiler. THere are scratch marks everywhere and broken chips out in many places. Anyone have an idea on how I can take this thing off and put another one on? I am just goign to buy a new spoiler, but I don't want to pay $100... just so Toyota can put it on. Any ideas?
    48,946
    no idea, but if it makes you and the missus feel any better, i have done this 3 times in reverse. i open the hatch, and forget about it. then, i open the garage door and the arm that connects the opener to the door catches the top edge of the spoiler and whammo! ugh.
  3. mickey513
    mickey513 Member
    127
    Cali
    Havn't looked up the price but I SERIOUSLY DOUBT the spoiler, if oem, is only $100.
  4. Roland1555
    Roland1555 Senior Member
    282
    68
    Vancouver BC
    I think op was talking about the cost of labor to have it installed by Toyota, but you're right... the price of the new spoiler would be closer to the $450 range, and it might need clips or the third brake light if it got damaged too.
    Roland.
  5. mickey513
    mickey513 Member
    127
    Cali
    Thanks, I read it wrong.
  6. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
  7. bisco
    48,946
    thanks, but does anybody know how to remove the old one and install the new? and can he order it in his color, or will he have to get it painted? can he paint it himself and save another hundred bucks?
  8. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    You can have any color you want--as long as it is black.
    Perhaps it is worth trying to patch, fill & touch up.
  9. Hokeysmoke
    Hokeysmoke Junior Member
    76
    Oregon
    I'm not a mechanic but it looks like in the Service Manual that it is held on with 5 nuts and comes off in one unit (with a dangling cable from the brake light). I think a more experienced person could chime in.
  10. bisco
    48,946
    no, it's pretty much mangled. would a body shop be able to fix it cheaper than buying and installing a new one?
  11. geethanr
    geethanr New Member
    Grayslake, IL
    Hi Folks,
    New to this forum. My wife did the same thing. Backed our Prius II out of the garage with rear hatch open and broke the black spoiler. I disconnected the brake cable. The spoiler looks good except for the broken brackets. Any suggestions on replacing it or trying to glue it back on.
    Thanks,
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If it is a clean break(s), I would try some strong epoxy. Never hurts to try.
    If that doesn't work, buy at a place like parts.com (mentioned earlier) and save about 50%.
  13. Mendel Leisk
    38,217
    Here's a thread on repair:
    http://priuschat.com/forums/gen-iii...363-gen-iii-spoiler-removal-w-photos-how.html
    (to find, Google: "Priuschat devil clips")
    We did a minor chew-up on ours, maybe a week after purchase: the garage door cleared the raised hatch when open, but if you closed the garage door it had a low hanging arm that, well...: didn't clear.
    I continue to have "oh s**t" moments, latest on a BC Ferry: flip the hatch, looked up, had missed some ceiling beam by maybe 1 inch, LOL.
    Just in case anyone from Toyota is reading: this thing should be made out of flexible rubber, and have an easy clip-on system, something that can hinge away if impacted, kind of like sideview mirrors. As-is, it is an expensive "glass jaw".
    ckk527 likes this.
  14. Mendel Leisk
    38,217
    Just for the heck of it I took mine off:
    You need to remove the 2 lower plastic panels on the hatch lid: the bottom one, and the smaller one directly behind the spoiler. There might be a way to avoid taking the big lower one off, but the two seem to be linked together at their joint, and once the lower one is off the upper one goes fairly easy.
    The upper one links to trim pieces running up the sides of the upper window glass: there's a couple of little tabs that need to be pushed out of position a little.
    The lower panel has a couple of little slot openings on either side edge: start there, use a trim panel removal tool with masking tape on it, take your time. It takes moderate up-lift, and finally the fasteners will start popping out. I had only one that stayed on the body, instead of coming off with the plastic panel. I removed it with careful prying with a fastener removal tool (they look like a mini crowbar) and re-installed in the plastic panel.
    The spoiler is held down with 5 studs, nuts accesable through access holes in the hatch. They seem to have locktite of some sort, a little reluctant to unscrew. Be careful not to drop the nuts into cavities. Then, disconnect the tail light lead.
    Then, lower the hatch gently, it'll likely click shut, doesn't matter. You would think you're done then, but you're wrong: there are 2 push-in fasteners still holding the spoiler down, one at each end, maybe 2 inches outboard of each end stud. There's little plastic panels on the end that can be sort of rotated, might help for getting a pry tool in, not sure. I basically just kept lifting up on it, almost getting the center studs out of their holes, and it finally popped free.
    Nothing to it :rolleyes:
    CR94, Robert Holt and Rebound like this.
  15. Arjay
    Arjay Junior Member
    Sooke, BC
    I am curious to see what the Prius looks like without the spoiler. Maybe it looks better? Did you take any pic's with it off?
    Cheers from VI!
  16. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    I broke mine a while back. It's easy to replace, assuming you can handle a socket wrench at all.
    Pop off the interior plastic panels.
    There are 5 nuts that hold the spoiler on, accessible from behind the panels.
    Don't drop the nuts and let them slide down inside the hatch sheet metal.
    Once on, close the hatch and pop in the two plastic snaps at both ends of the spoiler.
    The new one does not come with a new brake light. If you broke the light, order a new one of those too. Forcing the wire through to the access hole is tricky, but just shove it through. The connector is too big for the gap, but the spoiler will flex. You'll see what I mean when you get the new one.
    1 hour job, tops.
    Robert Holt likes this.
  17. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Then cover it with Carbon Fiber look vinyl and he won't even have to paint it. :rockon:
  18. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Duct tape. It works for NASCAR. :)
  19. Mendel Leisk
    38,217
    I recollect looking at it, spoiler off, and thinking: "I really should take a picture of this...". As far as it got, sorry.
    Anyways, it looks like a Prius without it's spoiler. Does not look like a Prius without it's wheel covers, ie: cool in a bare way. There's a big gap between the two glass areas, recessed a bit, with utilitarian ups and downs for strength, as I recall. Also kind of grubby.
  20. Arjay
    Arjay Junior Member
    Sooke, BC
    OK thanks for that Mendel. So it looks 'unfinished' - got it!
    Cheers.
