Need Help: Doors won't lock/unlock
Discussion in 'Newbie Forum' started by Luistorna1994, Dec 13, 2019.
  1. Luistorna1994
    Luistorna1994 New Member
    I own a 2012 Prius C and one day i couldn't unlock the car. The red light on my key fob blinks when i use it, but the doors still don't unlock. The only way to lock or unlock my car now is manually, the electronic lock switch on the doors don't work either. On the same day that this happened the ABS and Brake lights on the dashboard lit up for the first time. I've been reading around and seen that it might be the 12v battery, but I ran a diagnostic and it is working fine. I'm thinking it might be a fuse, or some messed up wiring, but im not sure.
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    There's a known problem with Prius C door lock systems... Yours sounds a bit different, but first step is to do a search on google with priuschat in the key words and do some reading up on the subject.
  3. Luistorna1994
    I've been searching for a few days and I can't find anything that exactly fits my situation. There are a lot of posts about the door lock actuator, but i don't think it's that. My doors won't even attempt to lock. I was hoping that someone on here has had the same issue as i do with the locks
    51,154
    can you describe 'working fine'?
  5. Luistorna1994
    I ran a diagnostic test on the car that checks the batteries health and it said it was running at 12 volts. And I dont see any other signs of a dying battery
  6. bisco
    51,154
    otherwise, car is working fine?
  7. Luistorna1994
    The only other problem is the thing with the brakes I mentioned in the first post. Everything else is working fine
  8. bisco
    51,154
    i think you'll have to read the trouble codes. i hope vermin haven't been chewing wires
  9. Luistorna1994
    What are trouble codes? I dont know much about this stuff. I only started doing research once my car started acting up
  10. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    What diagnostic did you run on the 12 volt?
  11. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    I agree, time to revisit that 12v test. Not everyone realizes that the difference between success and failure is only about one volt, when doing the simplest kind of open circuit testing.
    A fresh, fully charged battery with no load (car completely off or battery disconnected) should read around 12.70V.
    A 12.00 volt reading would suggest a battery that was significantly discharged or degraded.
    How old is that battery? A 2012 would normally be working on its second battery by now, maybe even third.
  12. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Unfortunately the 2012 does not have jump points under the hood.
    But wonder if you can hook up jumper cables to the batt (correct +/- on the terminals, to avoid messing things up)
    and see if key fob works correctly then.
    And as pointed out already, if 12v is the original, then likely the culprit.
    Low/expired 12v starts giving funny dash lights and issues that can be easily remedied by changing it out.
  13. Gator6
    Gator6 Junior Member
    Central KY
    I thought the 12v battery should read somewhere around 13.5 - 14 and change considering. If it is only reading 12, is that under a load? Have you disconnected the battery from the car (The negative terminal) and read the voltage across the terminals? Do you have a known, good 12v battery you can substitute in there or take a known, good, fully charged battery and a pair of jumper cables, attach it to the battery and see if your door locks operate. Even a lawn tractor battery should work for that.
  14. Luistorna1994
    There are a couple of questions here I need to address. The test I ran for the 12v was one that you could run from the prius itself. Here is a link to the video I watched that showed me how to do it.
    When i run this test it shows the battery at 12.0v. If I turn on the headlights, or roll down the window during the test the battery drops to around 11.3-11.7v and then goes back to 12v when I turn the headlights off, or when I stop rolling the windows. I thought that was ok, but judging from the comment above I might actually need a new battery.
    I dont know how old the battery is. I bought the car used about 3 years ago and I haven't had any issues with it until now.
    I also forgot to mention that the cruise control doesn't work anymore either. When I try it a message comes up that says "CHECK CRUISE CONTROL SYSTEM"
    Are there any other tests I can run on the battery to make sure that is definitely the issue?
  15. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    hmmm, you have a dash that looks like that?
    not sure the 2012 "c" has that internal dash 12v battery check.
    When I had mine, I wasnt aware, although many things i could prob add to that list
    Although a Gen3 (2012) would not have it either.
    Do you know how to access the 12v battery?
    If so, you could check to see it there is a date code on it, or see if it is oem.
    Could also keep it accessible and then after say 12 hours could use
    multimeter to check the resting voltage....but this cannot be done after drivers side door is opened.
    Perhaps keeping the back door unlocked and then turning off interior lights
    and then accessing it that way after the 12 hours of resting.
  16. Luistorna1994
    The dash in my car doesn't look like that, but i was still able to access the same menu using the same method they did in the video. The only difference is that they say to hold the "Info" button in the video. My car doesn't have an "info" button. I held down the "Car" button and did everything else the same.
  17. bisco
    51,154
    a dealer, or good hybrid shop has a tool called a code reader. it hooks up to the computer system at a port under the steering wheel.
    when you get trouble lights, you get trouble codes. the codes relate to a service manual trouble shooting tree which leads to problem diagnosis and repair.
    you can buy one for $25. on amazon (mini vci), but there is a learning curve, and you need a compatible laptop.
    or there are some phone apps which work pretty well, but not quite as detailed, so don't always lead to a solution.
    it all starts with a healthy 12v though, and that is tough to define when you get down around the level you're at.
    the computers need proper voltage to give correct codes.
    if you don't want to buy a new battery, you should at least try charging yours to see if it will hold at a higher voltage.
  18. Luistorna1994
    Thank you for the advice. I will definitely consider getting a code reader if it will help me. I am pretty inexperienced when it comes to repairing cars, especially hybrid cars. This is the first hybrid car I've owned. How do I charge the battery? Is it essentially like jumping a car, or do i have to buy a tool to do it?
  19. vvillovv
    4,318
    1,499
    NY
    There are youtubes showing howto change the 12volt on a 2012 prius c.
    Without knowing the codes that were set when the trouble started, none of us really knows much about what the problem is with the door locks. If you have an Auto Zone (auto parts store) near you and they are not too busy, they may plug there code reader into your car and show you what the codes are, sometimes even for no cost.
    Write the code(s) down and and post them here and we can help you figure out what the problem(s) are.
    #19 vvillovv, Dec 16, 2019
  20. Luistorna1994
    Theoretically, if it is the battery causing the problems, if i hook up a charger to the battery and attempt to lock/unlock the doors with the key fob, it should work. Is that correct?
    vvillovv likes this.
