Need Help!!! First Time Reconditioning.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Raphael, Dec 14, 2019.
  1. Raphael
    Raphael New Member
    BENICIA
    I currently have a gen 2 Prius and have taken the EV battery to recondition the cells.
    I am using a 4x balance charger and doing a discharge cycle of 1.0a to 6.0v and a charge cycle of 5.0a to 7500mAh. But the problem seems to be that some of the charge cycles get cut off early and I'm not sure why. Heres what my cycles are looking like:[​IMG] [​IMG]
  2. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    Who makes the charger? What model? What's date of manufacture? Not easy to help without this essential info!
  3. Raphael
    Raphael New Member
    BENICIA
    Fair enough here is the exact balance charge I am using EV-PEAK CQ3 LiPo Battery Balance Charger,100Wx4 10A Four Channel LiPo, LiHV, Life, NiCd, NiMh Battery Balance Charger Discharger
  4. PriusCamper
    11,104
    4,518
    Thanks for the info... Gonna research that charger type... The modules you're charging are significantly larger than the batteries these chargers are designed for. Having things shutoff too soon is always better than them shutting off too late, right? Most chargers have sensitivity settings you can change so it doesn't shut off early... But in general, it's wise to charge up a battery to max charge in stages so the heat does buildup too much and your cooling fans have an easier job to do.
